External antenna
Posted: 07 Aug 2017 14:09
I wan't to remove the built-in and add an external antenna. But I find the instructions unclear.
Normally an antenna has two leads, one for the core and one for ground. According to instructions I can either use point 4: open hole for pig tail, or point 5 for uFL connector. But point 5 has three soildering points.
What is the correct way to add external antenna?
