Create a sprinkler program
Posted: 26 Sep 2017 09:54
by billyboy
I have 3 sprinkler groups, which I want to scheduling after eachother for a different time for each zone.
It must be possible to start irrigation by a press of a button and by using a time scheduling.
I have looked very long to find a plugin for making this happen, but not succeeded.
How can help me or point me in the good direction?
Thanks!
Re: Create a sprinkler program
Posted: 30 Sep 2017 23:30
by jet11x
I spent a long time looking at options for adding a sprinkler system to my z-wave setup.
In the end I went with a different Raspberry PI solution -
https://opensprinkler.com/product/opensprinkler-pi/
Excellent hardware and good software.
Posted: 05 Oct 2017 10:01
by marco
Hi guys,
actually, while I agree with jet11x on the opensprinkler as a good solution, I can do something similar directly from zway using remaining GPIO pins of my rasp. Creating a Button device and using relevant string python commands to put a pin ON/OFF I can directly control several relays which can activate whatever I like...even electro valves for my garden
Posted: 06 Oct 2017 11:47
by billyboy
Thank you for responding.
From my z-way webinterface and through Apple Homekit I already can control the sprinkler valves. I am looking for a way to schedulling a sprinkler program. There are a lot of plugings, there must be one that I can use to achief this.
But which one? and how?
Posted: 03 Jun 2018 16:09
by billyboy
Still nobody has a answer?
Posted: 04 Jun 2018 07:58
by Eagle
Use the App escalation stages for automatically turning on/off each valve for your desired time.
Then shedule the, before created, escalation stages element with the app called shedule.
Posted: 04 Jun 2018 09:59
by billyboy
Thanks Eagle!! That is exactly what I needed!
