hardware upgrade RaZbeyrry 1.x to 2.x
Thomas
Post by Thomas »
Hello RaZberry
I have the old hardware version (the rectangular one without reset button) I have had all kinds of hassles, but interviews were very hard to make go through, and i never received any alarms, however timestamps for latest battery check would indeed trickle in every now and then. and i have firmware upgraded the card upgraded the loader, upgraded the z-wave.me soft upgraded raspbian - added the external antenna everything on the plant and in the forum - i decided the to by the new raZberry card v2, but is there an easy upgrade path, so i can "just" take the old card out, add the new one in, and all the devices are still there? Or do i better do a complete re-install?
Thomas
enbemokel
Re: hardware upgrade RaZbeyrry 1.x to 2.x
Post by enbemokel »
I´m using also both versions in different locations. Once I exchanged them for testing and this works without a problem.
You need the 2 backups from Expert Menu and from the Standard managment menu.
Then do a factory reset in expert menu, exchange the Razberrys and take back the backups. Don´t remember which one I
restored at once.
Worked for me, but I didn´t remeber which bootcode or sw version I used.
Maybe you get some more answers from other users.
