Why is Alexa failing again ?
Hisma
Re: Why is Alexa failing again ?
Post by Hisma »
Ha, I fixed it. Everything was fine. However, the instructions are not very clear. The z-way server will only include devices which you manually tell to enable with the alexa app. So I wasn't actually including any devices to be associated with alexa, as I didn't know it was required.
After selecting the check-box "lb_activate_alexa" in the devices I wanted to be discovered by alexa from inside the z-way server, it's now working correctly.
Phew!
Wikibear
Post by Wikibear »
"After selecting the check-box "lb_activate_alexa" in the devices"
Can you take a screenshot of this setting? I can't find this setting in my Smarthome.
Greatings from the noob
Wikibear
Post by Wikibear »
Oh, crazy... Found it! You must hit longer the device icon... Are there another way?
enbemokel
Post by enbemokel »
Puh, any better explanation? Didn´t find anything in Z-Way configuration or click and hold on icon ;-)
andreer
Post by andreer »
I have uninstalled Alexa in my iOS phone. I installed Amazon Alexa, but that doesn't work. All I tried was to reboot my Ios device. Do you have any Ios device key to run the applications?
enbemokel
Post by enbemokel »
enbemokel wrote:
30 Oct 2018 14:24
Haha, I just had to install the update then i could see the Alexa tag in the device. Didn´t saw the update the
last times......
Wikibear
Post by Wikibear »
My Skill at Amazon must connected to Switzerland... Alexa failed again...
After Skill deactivation the result is this:
Is there no way to change server request? Germany is working...
micky1500
Post by micky1500 »
Well that's an issue isn't it
Yes there is a way to change the Server.
This should be built into the 'Remote access' application. to check for a valid server.
Server says it is offline, but still is open for new connections :(.
So far I have had to block the offending ip address on my router.
Then it connects to a working server.
As mentioned previously in this topic 6 months ago. on 16 Jul 2018 21:46
Disabling/Enabling 'Remote Access' App will force a new attempt to connect.
login via telnet, sudo netstat -natlpe | egrep -i ssh and it will show what server you are connected to.
my connection shows 46.20.244.72:22 a working server. yippee
I checked today, a week later. Switzerland2 is still in failure.
Servers:-
Remote Server 1 Switzerland 46.20.244.72:22
Remote Server 2 Switzerland 185.25.224.111:22 (Failing)
Remote Server 3 Germany 78.46.43.211:22
Raspi 4(Buster), Zwave Version 3.0.6 x It's not my fault... I am not z-way team, just a user of a great system.
Wikibear
Post by Wikibear »
I don't change everything and then it's working without a problem. Today... It's failing again and this completely looks like no valid SSL cert. Status Page doesn't work zwave.de or a bad configured server... How ever... Alexa doesn't respond again.
http://support.zwave.eu/status/ not Found after bad cert...
johnmartinii
Post by johnmartinii »
Alexa is showing is some problems with the Ios devices as even some apps like Amazon Prime or Netflix is not working properly. I tried to work out with many apps https://showbox.expert/ but they are not working. They are saying that your device is updating but after updation, my all apps are crashed and phone get hanged up
