Z-way can not acces
AlesKO
Z-way can not acces
Post by AlesKO »
I would like to understand why sometimes (every few months) I can not access Z-Way remotely or locally from Rasp 3 (find.z-wave.me > Secure connection IP). It only helps to shut down / restart Rasp 3 (I also unplug/plug power supply but do not know if it is really necessery).
Othervise Raspberry works fine, just can not connect to z-way. Chrome says something like connection is not allowed to be established...
It is really rare situation but annoying when you are miles from your home. And you can do nothing.
How can I trace or find the reason?
Somebody has similar experience?
Alex
Re: Z-way can not acces
May be the s/w is crashing. If so, please tell us what are you using in your config. Especially do you use some HTTP devices?
AlesKO
Post by AlesKO »
I am using clean Raspbian install and RaZberzy.
Nothing else is installed, runnig or beeing connected to RPI.
It would be worh to look in the Z-Way log to see if it was up and running. Also was you internet connection ok?
