logrotate z-way-server has wrong file mode
ibjr
Post by ibjr »
After installing R3.0.0 the log file var/log/z-way-server does not rotate anymore so the file keeps growing in size over time.
It turns out that the mode of file /etc/logrotate.d/z-way-server is 0664.
Logrotate requires file mode 0644 or 0444
Manually changing the file mode solves the problem, but maybe this can be included in the installation scripts?
micky1500
Re: logrotate z-way-server has wrong file mode
Post by micky1500 »
I knew it was broken, as I had a file exceeding 900MB
sudo chmod 0644 /etc/logrotate.d/z-way-server
Thankyou to ibjr
Raspi 4(Buster), Zwave Version 3.0.6 x It's not my fault... I am not z-way team, just a user of a great system.
Thanks for the tip. Will become part of 3.0.1
himac
Post by himac »
PoltoS wrote:
16 Sep 2019 23:18
Hi, it is still not working in 3.0.1
Looks like. 3.0.2 then ;) soon
micky1500
Post by micky1500 »
After upgrading to 3.0.6 using web UI
logfile is not rotating and getting large >300MB
same issue as before
after 3.0.6 -rw-rw-r-- 1 root root 231 Apr 28 02:03 z-way-server 01/05/2020
ran chmod, now -rw-r--r-- 1 root root 231 Apr 28 02:03 z-way-server
Group write access affects logrotate?
micky1500
Post by micky1500 »
seems so, it wasn't working since 3.0.6
I did the old fix, sudo chmod 0644 /etc/logrotate.d/z-way-server
now its working.
