After installing R3.0.0 the log file var/log/z-way-server does not rotate anymore so the file keeps growing in size over time.
It turns out that the mode of file /etc/logrotate.d/z-way-server is 0664.
Logrotate requires file mode 0644 or 0444
Manually changing the file mode solves the problem, but maybe this can be included in the installation scripts?
logrotate z-way-server has wrong file mode
Re: logrotate z-way-server has wrong file mode
I knew it was broken, as I had a file exceeding 900MB
sudo chmod 0644 /etc/logrotate.d/z-way-server
Thankyou to ibjr
Thankyou to ibjr
Thanks for the tip. Will become part of 3.0.1
Looks like. 3.0.2 then soon
After upgrading to 3.0.6 using web UI
logfile is not rotating and getting large >300MB
same issue as before
after 3.0.6 -rw-rw-r-- 1 root root 231 Apr 28 02:03 z-way-server 01/05/2020
ran chmod, now -rw-r--r-- 1 root root 231 Apr 28 02:03 z-way-server
Group write access affects logrotate?
seems so, it wasn't working since 3.0.6
I did the old fix, sudo chmod 0644 /etc/logrotate.d/z-way-server
now its working.
now its working.
Hm.. deb package postinst file contains chmod 644 /etc/logrotate.d/z-way-server.... Since v3.0.2
I just looked in z-way-3.0.6_armhf.deb (downloaded on 28th April 2020) Extracting with 7-Zip
Found the file. C:\Z-Wave\Firmware\z-way-3.0.6_armhf.deb\data.tar\.\etc\logrotate.d\z-way-server
and the 'mode' column shows it with permissions -rw-rw-r--
All other files in the PI4 logrotate folder are set with permissions -rw-r--r-- (644)
and they work.
and they work.
