Script to change state on app.
elmaco
Post by elmaco »
Hello, is there a way to change the state on an app like Dummy_device outside the Z-wave server?
For an example a BashScript or python script.
Best regards/
Marcus
micky1500
Re: Script to change state on app.
Post by micky1500 »
I use Arduino to change z-wave device settings, so similar.
http://192.168.1.89:8083/ZAutomation/ap ... ommand/off
i got the device name by looking at the log.. tail -f /var/log/z-way-server.log
it gets more complicated tho, because you need to be logged on for it to work.
so python script is probably best.
elmaco
Post by elmaco »
Hi thanks for reply and it sound promising, but how do i include user and password, i have tried:
http://username:password@yourip:8083....
but it says "Not logged in" or"{"data":null,"code":401,"message":"401 Unauthorized","error":"Not logged in"}"
Any ides?
micky1500
Post by micky1500 »
That format works when I try it.
Try enabling API.
Configuration icon
APPS
Z-Wave Network Access
turn on - Enable Z-Wave API
elmaco
Post by elmaco »
Perfekt thanks.
So this is what i did, i made an Python script with this lines:
Import os
os.system('curl -s -LN --globoff http://user:password@IP:8083/ZAutomation/api/v1/devices/DummyDevice_33/command/on')
It might be an better way, but it does the job for me. :)
