Device seems to be dead after 05.36 Firmware Update
nachtfalke50
Re: Device seems to be dead after 05.36 Firmware Update
Post by nachtfalke50 »
OK, i have installed the z-way image https://razberry.z-wave.me/z-way-server ... ry.img.zip
The Version from z-way is 3.0.1 now. I get the same error.
Can it be that my razberry is dead? Is there a way to test it?
That was an expensive update to 5.36.
nachtfalke50
I don't know which firmware I started the update from. I think it was 5.7 or 5.5. But I can't get there anymore. I can see the dashed arrow in "https://service.z-wave.me/expertui/uzb- ... graph.html". But I can't download the software.
I need support (Access token) to do this. I hope my Razberry is not dead.
enbemokel
Post by enbemokel »
Hmm, I know that the Red LED is a bug, and it may has nothing to say. Also "Controller is dead" is normal .
I never tried to get a NIF from controller, but I can see two times failed, then I got a received. In History I got 8-9 times the source and destination
1 -1
Did you try to include a device while you are testing? Maybe it´s working and you are mislead from the first tries.
nachtfalke50
Hello enbemonkei,
Thank you for the advice. I exclude my devices again and i don't know why but now it works.
I think my diveces were not excluded correctly. I do an update from 5.23 to 5.36 and now it works.
The status of the "Static PC Controller" -> "Device seems to be dead" is obviously normal and is not a sign that something is wrong.
Thanks to all for the help!
We're you using EU frequency or another one? If upgrading from old firmwares EU frequency is set by default even if you were in US (was fixed around 5.2x).
Also are you sure to use 2 channels firmware for EU/US/ANZ and 3 ch for JP/TW?
