Upgrade RaZberry ZM5202 Firmware from 4.05 to ???
dbrunt
Post by dbrunt »
Is there newer firmware for my RaZberry Version: 4.05 (ZDK 6.51.6)?
Re: Upgrade RaZberry ZM5202 Firmware from 4.05 to ???
The latest version of the firmware is 5.38 based on 6.81.01. you can upgrade in the Expert UI
dbrunt
Post by dbrunt »
Thanks. I'm not using Z-Way but HomeSeer. Can I jump straight from 4.05 to 5.38 or are there version upgrade dependencies that need to be followed? When I look at https://service.z-wave.me/expertui/uzb- ... tml?hw=327 it appears there are but that diagram is quite confusing and does not list 4.05. If I can jump in one go, does firmware updating wipe the RaZberry as far as my current Z-Wave network setup? If Z-Way is the easiest and safest, if I shut down HS and re-install Z-Way onto my Pi, will it preserve my current HS Z-Wave network config through the upgrade?
Z-Way is the best way to upgrade, but HS do not run with latest firmwares (though we don't know why - they have just blocked them by firmware version).
dbrunt
Post by dbrunt »
Is there a tabular list of all downloadable 5202 firmwares which include dependencies (i.e. minimum version you can upgrade directly from) rather than the diagram at https://service.z-wave.me/expertui/uzb- ... tml?hw=327?
dbrunt
Post by dbrunt »
I fellow HS user claims he is running controller firmware 5.36 on a 5202.
brianaker
Post by brianaker »
Is 5.38 published?
The Expert UI is not showing an update for my controller, which is currently running 5.36.
We will release a new firmware soon
brianaker
Post by brianaker »
Has 5.38 been released?
I have never found a way to upgrade to it from the Expert UI.
not yes. This week
