Getting started with Code Device(s)
Posted: 04 Nov 2020 16:11
I am wondering how I would get started with Code Devices. My goal is to get custom devices that is not linked to actual z-wave hardware devices and I have a lot of sensors that would need to get updated. The reason I want to find a way to fit them into Z-way is that I have begun to collect all Z-wave devices and 433Mhz devices into Z-way running RaZberry on a Raspberry Pi
I have been looking around the forums but unfortuneatly i have no find a consistent documentation that is not on a very highly technical javascript level. I do understand that i will need javascript but thats is not the point im just trying to understand how to get started.
Looking around and finding resources that will get me started with Cod Devices and from what I have gathered are these:
Thanks to any readers and quite a junior on JS development and thanks for your patiance
- Technical reference manual stated several APIs and perhaps im lacking fundamental understanding how these are written now days.
- As I understand its the vDev with JS API Im supposed to get started with?
- https://gist.github.com/integrii/021f272f2cad0540fc3c : These got me started to find there is several ways to access the different APIs
- https://zwayhomeautomation.docs.apiary. ... ?console=1 : here i found a newer description of the next one below.
- https://github.com/Z-Wave-Me/home-autom ... ual-device : this dates back to 2013 though the reference manual seems to suggest that little has happened and should then be the same?
- Is it only the methods that are stated in various documents that are allowed? Can I alter a Code Device in a arbitary way such as metrics, types and how to update them? As I understand its both the JS and vDev/ZAutomation API that can do this? Is there a how-to I have missed somewere?
- I have started to test postman with http://my.secret.zwave.network:8083/ZAu ... v1/devices and I found the Code Device(s) listed there in a JSON format.
- As I understood from reading the forum, sensors are read-only, correct? Is there a way to get a custom code device to set the metrics, type and level to get a custom sensor with arbitary data to be updated? If so, am I in the correct path for doing this with vDev and the JS API?
