Cannot create vDev based on: 35-0-113: TypeError:
Zixwater
Post by Zixwater »
Im getting flooded by this error in the UI log:
Cannot create vDev based on: 35-0-113: TypeError: Cannot read property 'forEach' of null
This has started to appear after installing the UI version/firmware.
Software info
Firmware version	v3.1.1
UI version	v1.11.1
Built date	16-09-2020 01:08:41
Device:
Everspring Wall Plug Dimmer. Fully functional. Interview complete.
                "creationTime": 1605199497,
                "creatorId": 1,
                "customIcons": {},
                "deviceType": "sensorBinary",
                "h": 592601133,
                "hasHistory": false,
                "id": "ZWayVDev_zway_35-0-113-8-1-A",
                "location": 5,
                "locationName": "Bedroom (removed due to personal references)",
                "metrics": {
                    "icon": "alarm",
                    "level": "off",
                    "title": "Everspring Power Management Alarm (#35)",
                    "isFailed": false,
                    "modificationTime": 1605469800,
                    "lastLevel": "off"
                "nodeId": 35,
                "order": {
                    "rooms": 0,
                    "elements": 0,
                    "dashboard": 0,
                    "room": 1
                "permanently_hidden": false,
                "probeType": "alarm_power",
                "tags": [
                    "bedroom",
                    "management",
                    "powermeter"
                "visibility": true,
                "updateTime": 1605639604
This is getting to the point in which its to often, to much and also unbearable to have the app isntalled since this creates a push notification each it happens and having 100+ notifications after one hour is not longer an option.
Please direct me to logs where and why this could be happening. Ill supply what ever is needed!
piet66
Re: Cannot create vDev based on: 35-0-113: TypeError:
Post by piet66 »
This problem has been dealt with here in the forum many times. Please use the search function to get the solution.
The issue is coming up very often, always for command class 113. Seems Z-Way has a problem there. With the new notification function now it's more important than before to finally fix it.
RaZberry by Z-Wave.Me ZW0500 6.82.01 05.39/35498 1024/2
Z-Way version v3.1.2 from 2020-12-31
enbemokel
Post by enbemokel »
+1
Zixwater
Post by Zixwater »
piet66 wrote:
18 Nov 2020 11:35
Actually i did but i didnt find the answer the first time. The german thread i could understand.
The thread that solved it for me is -> https://forum.z-wave.me/viewtopic.php?p=88569#p88569
And it was the only thread that actually had an answer based on a serch for "Cannot create vDev based on:" but sure, problem solved(atleast the symptoms, the root cause i know nothing about) :)
piet66
Post by piet66 »
In any case it is right to point out again and again that the problem must finally be solved.
Finally we have found the issue. In v3.1.2 this will be fixed. Meanwhile a Force Interview is solving the problem.
enbemokel
Post by enbemokel »
Good news, even I hadn´t it a long time ago the last time. Thumbs Up
piet66
Post by piet66 »
I had it last 9 days ago.
ssvenn
Post by ssvenn »
Is there a way to throttle notifications? When this bug happens for me I just reboot the raspberry pi to reset everything and it will be fine for several weeks between each time it happens. I'm worried about if my gmail will start thinking z-way is spamming and begin to filter messages though.
The Z-way mail notifications are usually very useful but it's annoying to suddenly get notifications every few seconds. I would like to set a limit on how many it can send per minute.
Fingers crossed it is fixed in 3.1.2 as you say :)
Please do Force Interview on your device to fix it. v3.1.2 should fix it.
