Too far Z-Wave devices inclusion
alo1234
Post by alo1234 »
Just a question about the z-wave inclusion. When troubleshooting, or changing hardware, or updating the controller etc…I need to include some devices again. The Z-Wave controller is often far from the other devices and is not easily movable the devices aren't too. So I am looking for a solution that let me include the devices easily, by walking everywhere in the house where the devices are located.
Does any “portable” Z-Wave controller (like the Aeotec Z-Stick) can be included in an existing network as a secondary controller, then include some devices with it, and “transfer the inclusion” to the primary controller? This will be useful.
alo1234
Re: Too far Z-Wave devices inclusion
Post by alo1234 »
I'm using the raZberry shield with the Z-Way software
Better to include surrounding devices first, then those in range of step 1. Then those in range of step 2, ... Z-Wave uses NWI (Network Wide Inclusion) to include distant devices. No need to use direct range.
alo1234
Post by alo1234 »
Thanks for your answer. But what if the nearest device is even too far from the controller? Should I add a repeater just for the inclusion process?
alo1234
Post by alo1234 »
Sometimes the devices are too far for an inclusion, but ok for a "normal" communication.
It is quite rare that device do work reliably, but do not include at the same range. If inclusion fails, devices will show unreliable work, so better to add a repeater anyway
