After successful (?) update to Zway 3.2.0 the razberry server is no longer accessible. Upgrade and update of raspberry was not successful. What happened?
(no connection possible to server 192....)
Update to Zway 3.2.0 crashed system
Re: Update to Zway 3.2.0 crashed system
Manual start in terminal fixed the issue!
sudo LD_LIBRARY_PATH=./libs ./z-way-server
same issue by me
could you explain this command "sudo LD_LIBRARY_PATH=./libs ./z-way-server"
./z-way-server: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.28' not found (required by ./libs/libzwayjs.so)
I'm on stretch; fresh updated but something is missing ..
Zwave.me explained some basic commands how to interact with razberry with Terminal
(perhaps they were aware of the potential issues)
Please have a look here:
https://z-wave.me/support/how-to-report-a-bug/
distr upgrade to buster solved the issue
Is there no other option without upgrade to buster?
Have the same issue... A warning that this new version is not compatible to stretch was helpful...
Greatings from the noob
I had to upgrade to Buster a couple of months before already. It was due to a previous update.
But it worked
But it worked
Now I have a much more sever problem:
As I mentioned 3.2.0 did not start the z-way-server. I thought it was solved by starting manually. But it wasn't. I tried to include a new (Fiabaro-) device and failed. All of the device description were missing and therefore all individual configurations.
I tried to update the firmware but the firmware update failed and now a I a z wve server without firmware. Inconvenient situation.
How to solve? Can I upload the firmware from a file?
Update: complete new installation of Z-Way: wget -q -O - https://storage.z-wave.me/RaspbianInstall | sudo bash
Result: Cannot connect to server
