update not working
cbnidk
update not working
Post by cbnidk »
hi
I get this when I will update to 3.2.1 from 3.1.4
Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.
The following packages have unmet dependencies:
z-way-server : Depends: libmosquitto1 (>= 2.0.10) but it is not going to be installed
cbni
Re: update not working
This is due to Let's encrypt certificate root CA expiration. This certificate is used by Eclipse to oublish the libmosquitto.
Should be fixed by sudo apt-get update -y & sudo apt-get upgrade -y
