Raspbian bullseye problem with install Z-wave.me
niva004
Post by niva004 »
I have a question about support z-wave Software on Raspbian 11 (bullseye).
I just tried this command "sudo wget -q -O - http://razberry.z-wave.me/install | sudo bash", and i got information " Your Raspbian distribution is currently not supported by Z-Way, Please contact Z-Wave.Me support for more information"
Can anyone help me?, i tried to install manually
"sudo dpkg -i z-way-3.2.1_armhf.deb" and resolve dependiences, unfortunately one ist still missing "z-way-server depends on libwebsockets8;", on Debian 11 ist new version of libwebsockets16.
Thanks in advice
Pawel
Re: Raspbian bullseye problem with install Z-wave.me
We are working on this issue. Soon we will support bulleye
hellota
Post by hellota »
Could you please share a prognosis for Bulleye support?
Just in the progress os migrating to a new PI
We have a test build that supports both bullseye and buster:
PKG=z-way-3.2.1-29-g6bdd76fe_armhf.deb && wget -O /tmp/$PKG https://storage.z-wave.me/z-way-server/$PKG && sudo dpkg -i /tmp/$PKG
It might give you an error due to missing libmosquitto1. If so, just do
sudo apt --fix-broken install
Also, note that until the release WebSockets client will also not work. Only a few customers are using it, so I'll not post a recipe here - this will be fixed in a few days once the official release is out.
Bullseye is now supported. Please follow the standard installation process.
Read more: https://forum.z-wave.me/viewtopic.php?p=91811#p91811
russzz57
Post by russzz57 »
FYI for Me similar issue reported - https://forum.z-wave.me/viewtopic.php?f=3422&t=34788
caused by my version of Raspian Bullseye arm64 installed, which one it is not yet supported by Z-wave.me, only version arm32 works.
I need to uninstall my OS and re-install the supported one.
