Z-Wave Razberry installation issue on Raspberry PI4
Posted: 13 Dec 2021 00:45
Good Evening,
I am new in this world and i just register today into this formidable Forum- I hope that you can provide me your Help.
I bought a Z-Wave Razberry card, which has been installed into my Raspberry PI 4 .
I tried to install it from my SSH session but unfortunately I got the below error messages.
Please could you help me to troubleshoot this error ? Unfortunately i am not an expert of this new system.
What do I need to do to resolve this issue ?
1 – See below the result of this comand : wget -q -O - https://razberry.z-wave.me/install | sudo bash
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
webif:armhf : Depends: libssl1.0.2:armhf but it is not installable
z-way-full : Depends: z-way-server but it is not installable
Depends: webif but it is not installable
zbw : Depends: z-way-server but it is not installable
E: Unable to correct problems, you have held broken packages.
dpkg-query: no packages found matching z-way-server
dpkg-query: no packages found matching webif
dpkg-query: no packages found matching zbw
2 – See below the result of command : sudo apt-get update
pi@raspberrypiZZ1:~ $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
Hit:3 http://deb.debian.org/debian bullseye InRelease
Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
Hit:5 https://repo.z-wave.me/z-way/raspbian bullseye InRelease
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://repo.z-wave.me/z-way/raspbian bullseye InRelease' doesn't support architecture 'arm64'
3 – Result of command : cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL=https://bugs.debian.org/
Thanks and regards.
VERSION_ID="11"
ID=debian
Thanks and regards.
