Razberry 7 Pro Issues
z-wavettaja
Re: Razberry 7 Pro Issues
Post by z-wavettaja »
PoltoS wrote:
13 Apr 2022 01:22
hmm... from the log it is clear the board firmware has rebooted. Can you reproduce it? What do you do? Just request NIF? Only for device 61 or for any?
Yes, I can reproduce that.
In Expert UI I go to Device tab, open that device and push "Call for NIF". Then it generates those errors on log.
Only place, where I see this device 61, is in expert UI / Device / Status list. If I select control / Switch, that is not in list.
Also in normal UI in elements, there is not any element for device 61.
Issue seems to be only in this 61, all others seems to work, I can control them and "Call for NIF" example for this node 63 (whic is also Fibaro socket) is working, as you can see log below.
[2022-04-13 10:32:02.437] [I] [zway] Adding job: Request NIF from a node to node 63
[2022-04-13 10:32:02.445] [D] [zway] SENDING: ( 01 04 00 60 3F A4 )
[2022-04-13 10:32:02.447] [D] [zway] RECEIVED ACK
[2022-04-13 10:32:02.448] [D] [zway] RECEIVED: ( 01 04 01 60 01 9B )
[2022-04-13 10:32:02.448] [D] [zway] SENT ACK
[2022-04-13 10:32:02.449] [I] [zway] Job 0x60 (Request NIF from a node to node 63): Request for node 63 information frame sent
[2022-04-13 10:32:02.581] [D] [zway] RECEIVED: ( 01 13 00 49 84 3F 0D 04 10 01 5E 22 59 56 7A 32 71 73 98 31 96 )
[2022-04-13 10:32:02.581] [D] [zway] SENT ACK
[2022-04-13 10:32:02.581] [I] [zway] Node info received: 63
[2022-04-13 10:32:02.581] [D] [zway] SETDATA devices.63.data.basicType = 4 (0x00000004)
[2022-04-13 10:32:02.581] [D] [zway] SETDATA devices.63.data.genericType = 16 (0x00000010)
[2022-04-13 10:32:02.581] [D] [zway] SETDATA devices.63.data.specificType = 1 (0x00000001)
[2022-04-13 10:32:02.582] [D] [zway] SETDATA devices.63.data.deviceTypeString = "Binary Power Switch"
[2022-04-13 10:32:02.582] [D] [zway] SETDATA devices.63.data.nodeInfoFrame = byte[10]
[2022-04-13 10:32:02.582] [D] [zway]   ( 5E 22 59 56 7A 32 71 73 98 31 )
[2022-04-13 10:32:02.582] [D] [zway] SETDATA devices.63.data.lastReceived = 0 (0x00000000)
[2022-04-13 10:32:02.582] [I] [zway] Job 0x60 (Request NIF from a node to node 63): Node info received
[2022-04-13 10:32:02.582] [D] [zway] Job 0x60 (Request NIF from a node to node 63): success
[2022-04-13 10:32:02.582] [I] [zway] Removing job: Request NIF from a node to node 63
Raspi 4(Buster), Zwave Version 4.0.2 (7.28), Raz 7 Pro
Interesting... Please send a backup from the Expert UI. We will try to reproduce it, but I believe it will not be reproducible. Let's try.
Also are you on 7.13 firmware? If not, please try to upgrade first
z-wavettaja
I sent you a download link in PM. 7.17.00 is FW version at the moment.
micky1500
Post by micky1500 »
I am also getting the exact same errors in my log.
Not sure why.
[2022-04-15 10:20:16.722] [D] [zway] RECEIVED: ( 01 35 01 F8 08 02 01 11 07 05 00 00 00 00 00 00 00 00 38 ED 00 E0 00 00 00 00 01 01 01 01 FF FF 00 00 B0 1C 00 20 18 00 00 00 2D 9B 00 00 2C 9B 00 00 00 00 00 61 01 )
[2022-04-15 10:20:16.722] [D] [zway] Wrong checksum
[2022-04-15 10:20:16.722] [D] [zway] SENT NAK
[2022-04-15 10:20:16.722] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x10
… rest is same as other report
Raspi 4 - (Buster - 32 Bit) Zwave Version 4.1.1, Raz 7 Pro, Serial API Version: 07.38
Important is what you see few lines above. Please share. In this version of RaZberry we have added a notification about the chip reboot to faster get information about RaZberry 7 failures.
micky1500
Post by micky1500 »
Nothing above that looks important.
just usual rubbish upto 10 seconds ago
[2022-04-15 10:22:23.375] [zway] Removing job: Get background noise level
micky1500
Post by micky1500 »
The 01 35 01 Checksum failure comes un-announced !
Widen your view to compare the difference in these individual log entries.
[2022-04-15 10:22:27.435] [D] [zway] RECEIVED: ( 01 35 01 F8 08 02 01 11 07 05 00 00 00 00 00 00 00 00 38 ED 00 E0 00 00 00 00 01 01 01 01 FF FF 00 00 B0 1C 00 20 38 00 00 00 2D 9B 00 00 2C 9B 00 00 00 00 00 61 01 )
[---difference ---------] [D] [zway] RECEIVED: ( -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- xx -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- )
1 byte is different ! Isn't the checksum at the end, or isn't it shown at this level?
This mornings log. with previous history as requested.
[2022-04-16 06:01:45.497] [D] [zway] Job 0x3b: deleted from queue
[2022-04-16 06:01:55.097] [zway] Adding job: Get background noise level
[2022-04-16 06:01:55.105] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-04-16 06:01:55.106] [D] [zway] RECEIVED ACK
[2022-04-16 06:01:55.107] [D] [zway] RECEIVED: ( 01 07 01 3B 9A 98 98 7F 27 )
[2022-04-16 06:01:55.107] [D] [zway] SENT ACK
[2022-04-16 06:01:55.107] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 154 (0x0000009a)
[2022-04-16 06:01:55.107] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 152 (0x00000098)
[2022-04-16 06:01:55.107] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 152 (0x00000098)
[2022-04-16 06:01:55.107] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -102 dBm, Ch#2: -104 dBm, Ch#3: -104 dBm
[2022-04-16 06:01:55.107] [D] [zway] Job 0x3b (Get background noise level): success
[2022-04-16 06:01:55.107] [zway] Removing job: Get background noise level
[2022-04-16 06:02:01.601] [D] [zway] RECEIVED: ( 01 0C 00 04 00 10 03 80 03 52 A9 00 00 9C )
[2022-04-16 06:02:01.602] [D] [zway] SENT ACK
[2022-04-16 06:02:01.602] [D] [zway] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2022-04-16 06:02:01.602] [D] [zway] SETDATA devices.16.instances.0.commandClasses.128.data.history.82 = 1650085321 (0x625a4dc9)
[2022-04-16 06:02:01.602] [D] [zway] SETDATA devices.16.instances.0.commandClasses.128.data.last = 82 (0x00000052)
[2022-04-16 06:02:01.647] [D] [zway] RECEIVED: ( 01 0F 00 04 00 10 06 43 03 01 42 03 84 A9 00 00 CF )
[2022-04-16 06:02:01.647] [D] [zway] SENT ACK
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.instances.0.commandClasses.67.data.1.size = **********
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.instances.0.commandClasses.67.data.1.precision = **********
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.instances.0.commandClasses.67.data.1.deviceScale = 0 (0x00000000)
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.instances.0.commandClasses.67.data.1.deviceScaleString = "°C"
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.instances.0.commandClasses.67.data.1.val = 9.000000
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.instances.0.commandClasses.67.data.1.setVal = 9.000000
[2022-04-16 06:02:01.647] [D] [zway] SETDATA devices.16.instances.0.commandClasses.67.data.1 = Empty
[2022-04-16 06:02:01.674] [D] [zway] RECEIVED: ( 01 0F 00 04 00 10 06 43 03 01 42 03 84 A9 00 00 CF )
[2022-04-16 06:02:01.674] [D] [zway] SENT ACK
[2022-04-16 06:02:01.674] [W] [zway] Discarding duplicate packet from node 16
[2022-04-16 06:02:01.724] [D] [zway] RECEIVED: ( 01 0D 00 04 00 10 04 46 08 00 7F A9 00 00 7A )
[2022-04-16 06:02:01.724] [D] [zway] SENT ACK
[2022-04-16 06:02:01.724] [D] [zway] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2022-04-16 06:02:01.802] [D] [zway] RECEIVED: ( 01 0B 00 04 00 10 02 84 07 A9 00 00 C8 )
[2022-04-16 06:02:01.802] [D] [zway] SENT ACK
[2022-04-16 06:02:01.803] [D] [zway] SETDATA devices.16.data.lastReceived = 0 (0x00000000)
[2022-04-16 06:02:01.803] [zway] Node 16:0 CC Wakeup: Wakeup notification
[2022-04-16 06:02:01.803] [D] [zway] SETDATA devices.16.instances.0.commandClasses.132.data.lastWakeup = 1650085321 (0x625a4dc9)
[2022-04-16 06:02:01.803] [D] [zway] SETDATA devices.16.data.isAwake = True
[2022-04-16 06:02:01.803] [D] [zway] SETDATA devices.16.data.lastSendInternal = **********
[2022-04-16 06:02:01.803] [D] [zway] SETDATA devices.16.data.lastNonceGet = 114564893 (0x06d41f1d)
[2022-04-16 06:02:01.803] [D] [zway] Running wakeup handler for node 16
[2022-04-16 06:02:01.803] [D] [zway] SETDATA devices.16.instances.0.commandClasses.132.data.lastSleep = 1650085321 (0x625a4dc9)
[2022-04-16 06:02:01.803] [zway] Node 16:0 CC Wakeup: Send node to sleep
[2022-04-16 06:02:01.803] [zway] Adding job: Wakeup Sleep to node 16
[2022-04-16 06:02:01.803] [D] [zway] SENDING (cb 0x4f): ( 01 09 00 13 10 02 84 08 05 4F 31 )
[2022-04-16 06:02:01.805] [D] [zway] RECEIVED ACK
[2022-04-16 06:02:01.806] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2022-04-16 06:02:01.807] [D] [zway] SENT ACK
[2022-04-16 06:02:01.807] [D] [zway] Delivered to Z-Wave stack
[2022-04-16 06:02:01.937] [D] [zway] RECEIVED: ( 01 0B 00 04 00 10 02 84 07 A9 00 00 C8 )
[2022-04-16 06:02:01.937] [D] [zway] SENT ACK
[2022-04-16 06:02:01.938] [W] [zway] Discarding duplicate packet from node 16
[2022-04-16 06:02:07.568] [D] [zway] RECEIVED: ( 01 35 01 F8 08 02 01 11 07 05 00 00 00 00 00 00 00 00 38 ED 00 E0 10 00 00 00 FB 5A 00 20 0F 00 00 00 7C 59 00 20 08 00 00 00 1F 85 01 00 30 80 01 00 00 00 00 81 01 )
[2022-04-16 06:02:07.569] [D] [zway] Wrong checksum
[2022-04-16 06:02:07.569] [D] [zway] SENT NAK
[2022-04-16 06:02:07.569] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x10
[2022-04-16 06:02:07.569] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x00
[2022-04-16 06:02:07.569] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x0a
[2022-04-16 06:02:07.569] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x07
[2022-04-16 06:02:07.569] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x03
[2022-04-16 06:02:07.569] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x02
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x07
[2022-04-16 06:02:07.570] [D] [zway] RECEIVED ACK
[2022-04-16 06:02:07.570] [W] [zway] Received ACK, but there's no job awaiting ACK
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x5e
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x98
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x9f
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x6c
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x56
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x55
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0x00
[2022-04-16 06:02:07.570] [E] [zway] RECEIVED UNKNOWN PACKET TYPE: 0xd4
[2022-04-16 06:02:07.571] [D] [zway] RECEIVED: ( 01 10 00 0A 07 00 03 02 07 06 5E 98 9F 6C 56 55 00 D4 )
[2022-04-16 06:02:07.571] [D] [zway] SENT ACK
[2022-04-16 06:02:07.571] [W] [zway] No job of class 0x0a is waiting for callback 0x07
[2022-04-16 06:02:07.571] [zway] Unhandled callback for function 0x00
[2022-04-16 06:02:07.571] [zway] Removing job: Unknown function class
[2022-04-16 06:02:15.500] [D] [zway] Job 0x3b: deleted from queue
[2022-04-16 06:02:22.190] [zway] Job 0x13 (Wakeup Sleep to node 16): No callback received before timeout
[2022-04-16 06:02:22.190] [zway] Job 0x13 (Wakeup Sleep to node 16): Cancelling
[2022-04-16 06:02:22.190] [I] [zway] Adding job: Abort data send
[2022-04-16 06:02:22.191] [D] [zway] SETDATA devices.16.data.isAwake = False
[2022-04-16 06:02:22.191] [D] [zway] Sending the queue for node 16 into sleep
[2022-04-16 06:02:22.191] [D] [zway] SENDING: ( 01 03 00 16 EA )
[2022-04-16 06:02:22.192] [D] [zway] RECEIVED ACK
[2022-04-16 06:02:22.192] [I] [zway] Removing job: Abort data send
[2022-04-16 06:02:25.121] [I] [zway] Adding job: Get background noise level
[2022-04-16 06:02:25.122] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2022-04-16 06:02:25.123] [D] [zway] RECEIVED ACK
[2022-04-16 06:02:25.124] [D] [zway] RECEIVED: ( 01 07 01 3B 99 98 98 7F 24 )
[2022-04-16 06:02:25.124] [D] [zway] SENT ACK
[2022-04-16 06:02:25.124] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 153 (0x00000099)
[2022-04-16 06:02:25.124] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 152 (0x00000098)
[2022-04-16 06:02:25.125] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 152 (0x00000098)
[2022-04-16 06:02:25.125] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -103 dBm, Ch#2: -104 dBm, Ch#3: -104 dBm
[2022-04-16 06:02:25.125] [D] [zway] Job 0x3b (Get background noise level): success
[2022-04-16 06:02:25.125] [I] [zway] Removing job: Get background noise level
[2022-04-16 06:02:25.812] [D] [zway] RECEIVED: ( 01 0C 00 04 00 86 03 30 03 FF A8 00 00 16 )
[2022-04-16 06:02:25.813] [D] [zway] SENT ACK
[2022-04-16 06:02:25.813] [D] [zway] SETDATA devices.134.data.lastReceived = 0 (0x00000000)
[2022-04-16 06:02:25.813] [D] [zway] SETDATA devices.134.instances.0.commandClasses.48.data.1.level = True
[2022-04-16 06:02:25.813] [D] [zway] SETDATA devices.134.instances.0.commandClasses.48.data.1 = Empty
[2022-04-16 06:02:25.819] [I] [core] Notification: device-info (device-OnOff): {"dev":"PIR Passage","l":"on","location":11}
[2022-04-16 06:02:25.845] [I] [core] [BaseModule-9] Set lastLevel to on for ZWayVDev_zway_134-0-48-1 (was off)
[2022-04-16 06:02:26.078] [D] [zway] RECEIVED: ( 01 13 00 04 00 86 0A 71 05 00 00 00 FF 07 08 00 00 A7 00 00 47 )
[2022-04-16 06:02:26.078] [D] [zway] SENT ACK
[2022-04-16 06:02:26.078] [D] [zway] SETDATA devices.134.data.lastReceived = 0 (0x00000000)
[2022-04-16 06:02:26.079] [D] [zway] SETDATA devices.134.instances.0.commandClasses.113.data.7.eventParameters = byte[0]
[2022-04-16 06:02:26.079] [D] [zway] ( zero-length buffer )
[2022-04-16 06:02:26.079] [D] [zway] SETDATA devices.134.instances.0.commandClasses.113.data.7.event = 8 (0x00000008)
[2022-04-16 06:02:26.079] [D] [zway] SETDATA devices.134.instances.0.commandClasses.113.data.7.eventString = "Motion detected, location unknown"
[2022-04-16 06:02:26.079] [D] [zway] SETDATA devices.134.instances.0.commandClasses.113.data.7.status = 255 (0x000000ff)
[2022-04-16 06:02:26.080] [D] [zway] SETDATA devices.134.instances.0.commandClasses.113.data.7 = Empty
[2022-04-16 06:02:33.690] [D] [zway] RECEIVED: ( 01 0C 00 04 00 85 03 30 03 FF A8 00 00 15 )
[2022-04-16 06:02:33.690] [D] [zway] SENT ACK
thaui
interview is not finishing on a fibaro smart implant device
Post by thaui »
I have updated my systems with Razberry 7 controllers. It seems to be a mistake. My current FW is already 7.17. When icluding a Fibaro smart implant device with 3 1-wire sensors the interview is not finished correctly. The sensors do not appear as external devices. Just to be sure that the sensors are working I included the device with a series 5 contoller and everything is fine. Until now the Razberry 7 series are no advantage for me.
@micky1500, "01 35 01 F8 08" is a notification about firmware restart (due to watchdog). The checksum error - just ignore it, this is our bug in the restart notification, will be fixed in the new 7.21 and 7.28. But the fact that it reboots is bad - it is a SiLabs SDK issue and this is why we added those notifications - to know about problems in the SiLabs code. If you can upgrade to 7.17->7.21->7.28 (with all), please do and let's check the fixed "01 35 01 F8 08" with the exact place of reboot
micky1500
Post by micky1500 »
Yes, that seems fixed. Been on 7.28 about a week now.
Not seeing any "01 35 01 F8 08" occurrences.
Although I'm now seeing these in the Log !
Do I need to worry ?
[2022-06-28 15:32:33.751] [D] [zway] RECEIVED: ( 01 0F 00 04 00 85 06 31 05 03 0A 00 29 A6 00 00 C5 )
[2022-06-28 15:32:33.867] [D] [zway] SENT ACK
[2022-06-28 15:32:33.868] [D] [zway] SETDATA devices.133.data.lastReceived = 0 (0x00000000)
[2022-06-28 15:32:33.868] [D] [zway] SETDATA devices.133.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2022-06-28 15:32:33.868] [D] [zway] SETDATA devices.133.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2022-06-28 15:32:33.869] [D] [zway] SETDATA devices.133.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2022-06-28 15:32:33.869] [D] [zway] SETDATA devices.133.instances.0.commandClasses.49.data.3.val = 41.000000
[2022-06-28 15:32:33.869] [D] [zway] SETDATA devices.133.instances.0.commandClasses.49.data.3 = Empty
[2022-06-28 15:32:33.879] [core] Notification: device-info (device-luminiscence): {"dev":"Luminiscence","l":"41 Lux","location":10}
[2022-06-28 15:32:33.906] [core] [BaseModule-9] Set lastLevel to 41 for ZWayVDev_zway_133-0-49-3 (was 24)
[2022-06-28 15:32:36.044] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 00 80 20 00 20 78 30 00 20 8C 00 00 00 AC 1C 00 20 4B 00 00 00 EA 5F 00 20 00 70 07 00 01 9B 00 00 00 00 00 00 12 02 05 00 78 30 00 20 8C 00 00 01 4B 00 00 00 F7 5A 00 20 4A 00 00 00 05 00 00 00 F7 )
[2022-06-28 15:32:36.044] [D] [zway] SENT ACK
[2022-06-28 15:32:36.044] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 0
[2022-06-28 15:32:36.044] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.051] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 00 78 59 00 20 73 85 01 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF )
[2022-06-28 15:32:36.051] [D] [zway] SENT ACK
[2022-06-28 15:32:36.051] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 64
[2022-06-28 15:32:36.051] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.057] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF D3 9C 01 10 01 5D 82 2B AB 4A 40 A1 00 C0 00 00 10 C3 85 3D 08 70 00 00 00 00 00 00 00 00 00 00 00 00 FE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF B0 )
[2022-06-28 15:32:36.057] [D] [zway] SENT ACK
[2022-06-28 15:32:36.057] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 128
[2022-06-28 15:32:36.057] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.064] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FE FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F7 5A 00 20 50 00 00 00 C2 00 00 00 05 00 00 00 B5 3E 01 00 50 00 00 00 EB 55 01 00 F7 )
[2022-06-28 15:32:36.064] [D] [zway] SENT ACK
[2022-06-28 15:32:36.064] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 192
[2022-06-28 15:32:36.064] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.069] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 01 EA 5F 00 20 69 A9 01 00 83 60 00 20 05 00 00 00 CD 5F 00 20 01 00 00 00 01 00 00 00 43 60 00 20 05 00 00 00 E1 AB 01 00 0A 2B 0A 09 18 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 24 32 00 20 29 )
[2022-06-28 15:32:36.069] [D] [zway] SENT ACK
[2022-06-28 15:32:36.069] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 0
[2022-06-28 15:32:36.070] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.076] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 01 18 00 00 00 00 00 00 00 24 32 00 20 36 00 00 00 22 32 00 20 84 60 00 20 18 00 00 00 86 60 00 20 70 39 00 20 4B AC 01 00 24 32 00 20 85 60 00 20 00 00 00 00 00 00 00 00 45 60 00 20 31 B3 01 00 C0 )
[2022-06-28 15:32:36.076] [D] [zway] SENT ACK
[2022-06-28 15:32:36.076] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 64
[2022-06-28 15:32:36.077] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.082] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 01 00 00 00 FE 40 27 0A 09 18 00 00 00 00 00 00 00 00 00 00 00 18 00 00 00 00 00 00 00 30 49 00 20 24 32 00 20 22 32 00 20 83 60 00 20 45 60 00 20 70 39 00 20 73 B4 01 00 22 32 00 20 80 4D 00 20 B9 )
[2022-06-28 15:32:36.082] [D] [zway] SENT ACK
[2022-06-28 15:32:36.082] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 128
[2022-06-28 15:32:36.082] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.089] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 01 00 00 00 00 30 49 00 20 18 00 00 00 43 47 00 20 00 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 BF FD 00 00 23 32 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 02 00 00 00 9D )
[2022-06-28 15:32:36.089] [D] [zway] SENT ACK
[2022-06-28 15:32:36.089] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 192
[2022-06-28 15:32:36.089] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.096] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 02 A4 4D 00 20 04 00 00 00 01 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A7 AD 00 00 8D 27 01 00 FF 7F 00 00 60 39 00 20 07 00 00 00 80 00 00 00 D1 A8 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 80 00 00 00 A1 )
[2022-06-28 15:32:36.096] [D] [zway] SENT ACK
[2022-06-28 15:32:36.096] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 0
[2022-06-28 15:32:36.096] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.102] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 02 00 00 00 00 30 3A 00 20 98 5A 00 20 9C 5A 00 20 C4 39 00 20 3F B9 00 00 A5 A5 A5 A5 D3 96 01 02 07 A5 A5 A5 00 01 00 7F 1E 00 8C 00 3A 6F 00 20 81 B5 00 00 1D B5 00 00 F5 B5 00 00 CD B4 00 00 A6 )
[2022-06-28 15:32:36.102] [D] [zway] SENT ACK
[2022-06-28 15:32:36.102] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 64
[2022-06-28 15:32:36.102] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.109] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 02 C4 39 00 20 00 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 47 3D 00 00 A5 A5 A5 A5 84 2F 00 20 00 00 00 00 90 17 00 20 90 17 00 20 D4 32 00 20 88 17 00 20 0B 00 00 00 95 )
[2022-06-28 15:32:36.109] [D] [zway] SENT ACK
[2022-06-28 15:32:36.109] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 128
[2022-06-28 15:32:36.109] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.114] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 02 B0 18 00 20 B0 18 00 20 D4 32 00 20 00 00 00 00 2D 00 00 00 D4 20 00 20 5A 2D 57 61 76 65 20 00 00 00 00 00 02 00 00 00 00 00 00 00 2D 00 00 00 00 00 00 00 80 00 00 00 02 02 00 00 00 00 00 00 69 )
[2022-06-28 15:32:36.114] [D] [zway] SENT ACK
[2022-06-28 15:32:36.114] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 192
[2022-06-28 15:32:36.114] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.121] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 03 00 00 00 00 00 00 00 00 58 56 00 20 00 01 00 00 08 7D 02 00 07 00 00 00 64 3C 00 20 14 3C 00 20 30 3B 00 20 9C 3B 00 20 C4 39 00 20 A8 81 02 00 F0 3B 00 20 EC 3B 00 20 00 3C 00 20 52 00 00 00 6D )
[2022-06-28 15:32:36.121] [D] [zway] SENT ACK
[2022-06-28 15:32:36.121] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 0
[2022-06-28 15:32:36.121] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.127] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 03 00 00 00 00 00 00 01 00 00 00 00 00 28 01 00 20 00 00 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 02 )
[2022-06-28 15:32:36.127] [D] [zway] SENT ACK
[2022-06-28 15:32:36.127] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 64
[2022-06-28 15:32:36.127] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.134] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 03 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 CA )
[2022-06-28 15:32:36.134] [D] [zway] SENT ACK
[2022-06-28 15:32:36.134] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 128
[2022-06-28 15:32:36.134] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.139] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 03 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 8A )
[2022-06-28 15:32:36.139] [D] [zway] SENT ACK
[2022-06-28 15:32:36.140] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 192
[2022-06-28 15:32:36.140] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.146] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 04 58 34 00 20 08 00 00 2E D8 1C 00 20 D8 1C 00 20 9A B2 00 00 5C 34 00 20 00 00 00 00 01 00 00 00 00 06 8A EA 00 06 8A FA 00 06 8A FA 08 00 00 B8 DE 00 00 A8 D8 1C 00 20 00 00 00 00 B0 E7 07 00 52 )
[2022-06-28 15:32:36.146] [D] [zway] SENT ACK
[2022-06-28 15:32:36.147] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 0
[2022-06-28 15:32:36.147] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.153] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 04 80 20 00 20 01 00 00 00 9C 34 00 20 D7 09 8A 0F D8 1C 00 20 D8 1C 00 20 F3 34 00 20 20 FF FF 3F FF FF FF FF 00 00 00 00 D7 09 8A 7A D7 09 8A 7A 80 0E 81 E2 8C 00 00 B4 14 80 07 00 D8 1C 00 20 05 )
[2022-06-28 15:32:36.153] [D] [zway] SENT ACK
[2022-06-28 15:32:36.154] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 64
[2022-06-28 15:32:36.154] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.159] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 04 5D B4 07 00 13 14 05 00 D8 1C 00 20 3F 35 00 20 D8 1C 00 20 A5 A5 A5 A5 A5 A5 A5 A5 79 88 00 00 F3 34 00 20 D8 1C 00 20 00 02 00 00 00 00 00 00 68 1C 00 20 7F 1C 00 20 4C 1C 00 20 01 00 00 00 9D )
[2022-06-28 15:32:36.159] [D] [zway] SENT ACK
[2022-06-28 15:32:36.159] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 128
[2022-06-28 15:32:36.159] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.166] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 04 74 1C 00 20 A5 A5 A5 A5 A5 A5 A5 A5 ED FF FF FF 00 00 00 00 01 00 00 00 A4 18 00 20 70 18 00 20 04 14 00 20 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 04 14 00 20 00 E0 00 E0 00 00 00 10 12 )
[2022-06-28 15:32:36.166] [D] [zway] SENT ACK
[2022-06-28 15:32:36.166] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 192
[2022-06-28 15:32:36.166] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.172] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 05 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 ED FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5E )
[2022-06-28 15:32:36.172] [D] [zway] SENT ACK
[2022-06-28 15:32:36.172] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 0
[2022-06-28 15:32:36.172] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.179] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 01 00 00 00 02 00 00 00 3C 00 00 00 FD 9C 00 00 FE 4E 00 00 00 00 00 61 00 00 00 00 00 00 00 00 82 )
[2022-06-28 15:32:36.179] [D] [zway] SENT ACK
[2022-06-28 15:32:36.179] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 64
[2022-06-28 15:32:36.179] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.184] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 4E 00 00 7D )
[2022-06-28 15:32:36.184] [D] [zway] SENT ACK
[2022-06-28 15:32:36.184] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 128
[2022-06-28 15:32:36.184] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.191] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 05 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 47 3D 00 00 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 F6 )
[2022-06-28 15:32:36.191] [D] [zway] SENT ACK
[2022-06-28 15:32:36.191] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 192
[2022-06-28 15:32:36.191] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.198] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 4F )
[2022-06-28 15:32:36.198] [D] [zway] SENT ACK
[2022-06-28 15:32:36.198] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 0
[2022-06-28 15:32:36.198] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.204] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 40 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 0F )
[2022-06-28 15:32:36.204] [D] [zway] SENT ACK
[2022-06-28 15:32:36.204] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 64
[2022-06-28 15:32:36.204] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.211] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 80 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 CF )
[2022-06-28 15:32:36.211] [D] [zway] SENT ACK
[2022-06-28 15:32:36.211] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 128
[2022-06-28 15:32:36.211] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.216] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 C0 06 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 8F )
[2022-06-28 15:32:36.217] [D] [zway] SENT ACK
[2022-06-28 15:32:36.217] [E] [zway] Packet FC::ZMESerialAPIOptionsCallback: unknown callback type 192
[2022-06-28 15:32:36.217] [E] [zway] Error returned from (fc->callbackFunc)(zway, cjob, size, buffer): Wrong packet from Z-Wave network or Discovery got bad data (stick communication failed) (-9)
[2022-06-28 15:32:36.223] [D] [zway] RECEIVED: ( 01 47 00 F8 08 01 00 07 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 A5 4E )
[2022-06-28 15:32:36.224] [D] [zway] SENT ACK
