Page 1 of 3
RaZberry 7 Pro - Long Range
Posted: 11 Jul 2022 06:53
by N2641D
Today I received a RaZberry 7 Pro device (US version) which I attached to a RASPI 4B. Using the Z-Wave Expert UI I'm unfortunately unable to switch to Long Range as it is not enabled (message: Long Range is not supported or not enabled in your hardrware). Switching the operating frequency to "US Long Range" creates the message: "Current frequency: unsupported".
Firmware version: v3.2.3
UI version: v1.13.5
Built date: 06-04-2022 02:42:33
Capabilities: slm
Can somebody please help?
Thanks.
Re: RaZberry 7 Pro - Long Range
Posted: 11 Jul 2022 07:20
by lanbrown
You need the 4.0 release as discussed on this very forum.
Posted: 11 Jul 2022 18:31
by N2641D
Thank you for your quick reply!
Z-Wave Expert UI shows me:
The current firmware version is: 7.13 [Bootloader: 1766938484]
Is this the required version? If not, where can I download the version which supports Long Range?
Posted: 11 Jul 2022 19:50
by micky1500
It's not ready yet.
You need to update the RASBI 4B to z-way 4.0
https://razberry.z-wave.me/z-way-server/
And 7pro firmware update at the same time to the latest.
You can't do it now, have to wait a bit longer.
Posted: 12 Jul 2022 00:47
by N2641D
I see... Thanks for your update.
Are there any dates announced for that update?
Posted: 14 Jul 2022 01:13
Hello!
You can use the 4.0 release candidate form here: https://storage.z-wave.me/z-way-server/ (click on more for the RPi version to see 4.0.0 release candidate).
The official 4.0 release should by August.
Posted: 16 Jul 2022 06:58
by N2641D
Thank you. "click on more" was the trick I was looking for :-)
Posted: 19 Jul 2022 21:21
by swamplynx
Were you able to get this to work?
I’ve updated to the 4.0 RC and firmware to 7.28 on my raZberry 7.0 Pro. Under the Expert UI I am able to change the frequency to “US Long Range,” but under controller info it still has an X for Long Range support. Rebooting also reverts the frequency to US. What am I missing?
Posted: 20 Jul 2022 01:49
Starting from 7.28 to enable Long Range support you should explicitly activate it. This part is not fully added in the Z-Way. We can guide you how to enable it. First please take the uuid from the Controller info page (where the X is) and got here: https://z-wave.me/hardware-capabilities
Once you activate the free LR option, you will be able to add it in your hardware. Soon Z-Way will apply it automatically, but for now it is a had work. I'll guide you
Posted: 20 Jul 2022 02:23
by swamplynx
Thanks, but when I go to that site it is blank for both my UUIDs (I have two raZberry 7s).
0000000000000000842e14fffe62f1b5
0000000000000000842e14fffe62efe4
