Razberry 2 - firmware version 4.02
g_bremmer
Post by g_bremmer »
I'm trying to update my Razberry, but I can't find the firmware to upgrade from 4.x to 5. Who can help me?
I'm using the tool:
zmeserialupdater
https://z-wave.me/support/zmeserialupdater-manual/
Re: Razberry 2 - firmware version 4.02
Hello! Firmware 4.02 never existed.
g_bremmer
Post by g_bremmer »
You are right, it's 4.2. How do I upgrade from 4.2 to 5.x?
micky1500
Post by micky1500 »
Nope..
4.2 and 5.x do not exist on z-way.
You are in the wrong forum.
Try Google search.
lanbrown
Post by lanbrown »
micky1500 wrote:
14 Jul 2022 21:57
Nope..
Try Google search.
Not true. The previous Razberry board based upon the 500 series chip:
Firmware
SDK Version: 6.82.01
Serial API Version: 05.39
The OP is asking about the firmware and hence why the title states Razberry 2 - firmware.
RaZberry 2 firmwares
5.39: Added Zniffer feature to trap packets between devices in own network. Updated SDK to 6.82.01
5.38: Production test fixed
5.37: Updated SDK to 6.81.01. Fixed blink on sending and on SmartStart init. Reporting of incoming routes added in Z-Way Reoute Map.
5.32: Updated SDK to 6.81.00 Smart Start support.
5.27: Added Bridge version and RF test mode.
To run the RF test mode do: sudo /etc/init.d/z-way-server stop && sudo apt-get install git && cd /tmp && rm -Rf uSAPI && git clone https://github.com/Z-Wave-Me/uSAPI && cd uSAPI && make && ./uSAPI -b "F7 01" -p /dev/ttyAMA0 -r 1 && ./uSAPI -b "08" -p /dev/ttyAMA0
5.27: Added radio jam detection feature.
5.26: Added forgotten new IMA functions.
5.25: Minor fixes.
5.23: Updated SDK to 6.71.01.
5.22: Frequency not resetted to EU anymore on upgrade.
5.16: Updated SDK to 6.70.00.
5.07: Updated SDK to 6.51.09 (for certification)
5.06: LED can be turned off: Change it via IP:8083/JS/Run/zway.NVMExtWriteLongBuffer(0x6510,[XX]), where XX is:
0x00 LED used only for memory test when device powers up. Silent mode.
0x01 LED used during memory test and to indicate inclusion/exclusion mode.
0x03 LED used during memory test, to indicate inclusion/exclusion mode and it blinks when data is sending.
5.05: Fixed Bootloader upgrade response.
5.04: LED not turning off after some operations fixed.
Offset of User NVM made static.
5.03: Fixed bug with wrong UID returned after license apply.
micky1500
Post by micky1500 »
As you said.. The OP is asking about the firmware and hence why the title states Razberry 2 - firmware.
Maybe I overstated by saying "4.2 and 5.x do not exist on z-way"
yes 5.xx does exist.
Back in 2016 The firmware was 5.02 on Gen 3 Hardware.
Firmware 4.02 or 4.2! As I am aware of has never been released.
Yes 4.0.0.2 Software has recently been available. But I wouldn't class that as Firmware.
You cannot upgrade Firmware from 4.2 to 5.xx, Because Firmware 4.2 never existed.
Doesn't mater what 5.xx is available.
if OP is on 4.2 now, he needs to Clarify what Hardware device he is using.
My Original answer still stands.
Use Google to identify it !
