RaZberry HAT & Bullseye
simonagjerner
Post by simonagjerner »
Hi Everyone,
I just got my RockPi4. It works fine so far and I use it as a server for my smarthome.
It has Dietpi installed, which is based on Debian Bullseye.
Now the problem:
I’d like to use a RaZberry-HAT, which is for Z-Wave.
But when I attach the hat, the RockPi will not boot-up. I found this to be a well-known problem.
(See here: https://wiki.radxa.com/Rockpi4/hardware/HATs 8)
Obviously I need to tweak my config, but here is the problem:
There is no suitable repository for Bullseye :frowning:
Do you guys have any idea how I could make this work with any other steps or what else I could do? This is a discussion that the a.m. link refers to: Configuring kernel before building 3)
Any help would be much appreciated!
Regards,
Simona
Re: RaZberry HAT & Bullseye
You need to disable the serial console as stated on that page. Do it before installing RaZberry as otherwise, it will prevent the system to boot (on boot the kernel will try to talk with RaZberry, but RaZberry won't understand that).
