FGBS-001 Universal Sensor stopped working with upgrade to RaZberry 7 Pro
ml_zway
Post by ml_zway »
I switched to a RaZberry 7 Pro and my FGBS-001 Universal Sensor is no longer sending reports when IN1 changes. The logs show the below:
[2023-03-17 10:12:59.022] [D] [zway] SETDATA devices.41.data.lastReceived = 0 (0x00000000)
[2023-03-17 10:12:59.023] [W] [zway] Ignoring Set packet recieved on lower security scheme Plain text than our highest S0 (acceptSetSecurityLevel is not set)
[2023-03-17 10:12:59.023] [E] [zway] Error returned from (returnStatus = _zway_cc_call_handler(zway, instance, node_id, data[3], length - 4, &data[4])): Function class not supported by the hardware (-4)
In another post (Binary sensor is always off), I tried mapBasicSetToSpecificReport=true which didn't seem to change anything. I also saw: Most likely you need to enable the option to "accept report commands without encryption"
Which seems reasonable but I'm not sure how to do that ? Or is there anything else I can try other than upgrading to a Smart Implant.
Thanks for your help,
Re: FGBS-001 Universal Sensor stopped working with upgrade to RaZberry 7 Pro
you also need acceptUnsecureSet to be 0. Please use the Expert UI > Configuration > Expert Commands > (on the bottom) to configure this
This is not because of RaZberry 7, but due to the Z-Way upgrade - not it is more strict with unsecure commands
ml_zway
Post by ml_zway »
Perfect, thank you:
Configuration | Expert Commands | Device Settings
acceptSetSecurityLevel=0
I am now receiving the events.
