Neighborlist Razberry 7 pro not updated
Posted: 05 Aug 2023 16:49
by memphiz
I have a problem after i had to move my controller to a different place.
When i perform a complete network heal(or a heal of a single device) my razberry 7 is not updating its neighborlist.
Even when I put a device directly to the conroller, the device finds node 1 as neighbor, but the controllers list stays unchanged.
I'm on FW 7.38. Can this be fixed?
Greetings,
Olli
Re: Neighborlist Razberry 7 pro not updated
Posted: 09 Aug 2023 04:23
Don't look at the first line. Look at the first column
Posted: 14 Aug 2023 22:35
by memphiz
Thanks for the reply, but does not the column show which devices see the controller directly?
Anyway, it is not only a problem of view. Even after multiple network heals, the network remains extremely unstable and laggy.the conroller probably wants to reach devices directly that it can't reach. Or it tries to route data, although directly reachable.
If I transfer a nvm backup from razberry 7 to another conroller (e.g. razberry 2), then heal once everything fits and everything runs fine.
From this I can make a backup/restore to the razberry 7 again, everything works fine then.
I move the controller at the moment quite often, because I'm still looking for the best place in the house. But that does not seem to work at all with razberry 7 pro.
