Page 1 of 2
4.1.2 Razberry zw0700 error
Posted: 04 Mar 2024 21:22
by otverber
hello
Get this error using RaZberry Configuration Interface, when trying to restart z wave or reboot :
Err(1.18.3): main.c: 501: The spawned process 'shell:/bin/systemctl stop netif.$IFACE' has exited with code 5 and says:
but no message indicated.
any ideas to fix this?
RaZberry by Z-Wave.Me
Vendors Product ID: 1025 / 257
Z-Wave Chip: ZW0700
Re: 4.1.2 Razberry zw0700 error
Posted: 11 Mar 2024 22:46
Are you trying to do reboot in the :8084 UI?
Posted: 12 Mar 2024 12:55
by otverber
Trying to Z-Wave restart in the firmware update menu
gives this message and no restart of z-wave
2024-03-12 (1).png (64.45 KiB) Viewed 79294 times
Posted: 14 Mar 2024 04:03
We will check it. Meanwhile please ssh to your box and do
sudo /etc/init.d/z-way-server restart
Posted: 12 Apr 2024 15:03
by otverber
restart via ssh "sudo /etc/init.d/z-way-server restart" works .
regards
Posted: 16 Jul 2024 23:04
by otverber
this problem still persists.
had to do a sudo update and upgrade to get to 4.1.3 today
any clues how to make the menu work as intended yet?
Posted: 07 Aug 2024 15:31
please update to the new zbw and z-way-server. Then it should be fixed
Posted: 12 Aug 2024 11:42
by otverber
Upgrade to 4.1.4 trough the interface worked, but the same error message occured during the process, I.e. no upgrade in process window active.
After upgrade, the select z-way restart in the system/advanced menu brings up the same error message as before..
Not fixed then ?
Best regards
Posted: 19 Aug 2024 14:22
Looks, our list of IP interfaces does not match yours. Please do:
ip a; ip l
Posted: 26 Aug 2024 23:35
by otverber
pi@raspberrypi:~ $ ip a ; ip l
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:3a:59:bf brd ff:ff:ff:ff:ff:ff
inet 192.168.0.200/24 brd 192.168.0.255 scope global noprefixroute eth0
inet6 2a02:fe1:b17b:3b00:f9a8:f9ac:e880:d500/128 scope global dynamic noprefixroute
valid_lft 3195sec preferred_lft 1395sec
inet6 fdaa:bbcc:ddee:0:f62b:7aeb:d0c4:c255/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 21474820sec preferred_lft 21474820sec
inet6 2a02:fe1:b17b:3b00:3b9d:7991:b933:d9aa/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 1209584sec preferred_lft 604784sec
inet6 fe80::bcbb:b91d:3374:e7d7/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:6f:0c:ea brd ff:ff:ff:ff:ff:ff
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DORMANT group default qlen 1000
hope this gives a clue?
best regards
