Changing thermostat setpoint not working
tester
Post by tester »
I am communicating to a IS-ZW-STAT-100 GE thermostat with ZWave USnap module.
The product is working fine in standalone mode.
The product seems to be working in ZWave mode, as I can change the mode to heat through ZWave. The following commands work fine:
192.168.2.1:8083/ZWaveAPI/Run/devices[30].ThermostatMode.Set(1)
192.168.2.1:8083/ZWaveAPI/Run/devices[30].instances[0].commandClasses[0x40].Set(1)
However, I cannot change the Heat setpoint (either using F or C). The following do not work:
192.168.2.1:8083/ZWaveAPI/Run/devices[30].ThermostatSetPoint.Set(1,26)
192.168.2.1:8083/ZWaveAPI/Run/devices[30].ThermostatSetPoint.Set(1,80)
192.168.2.1:8083/ZWaveAPI/Run/devices[30].instances[0].commandClasses[0x43].Set(1,26)
192.168.2.1:8083/ZWaveAPI/Run/devices[30].instances[0].commandClasses[0x43].Set(1,80)
A similar reaction occurs when I use the the web interface, http://192.168.2.1:8083, and try "Device control", "Thermostats" or "For experts", "Expert commands".
A Wayne Dalton WDTC-20 thermostat in the same setup works fine using either of the commands listed above to change its setpoint.
Any suggestions on how to change the heat setpoint on the GE thermostat using the ZWave commands? Any ideas as to why the GE thermostat does not work, while the Wayne Dalton does work?
Thanks.
We have fixed this in our
We have fixed this in our beta (will be released soon). Please wait a bit.
tester
Progress on thermostat?
Post by tester »
I wonder if progress has been made on the making your product work with the IS-ZW-STAT-100 GE thermostat? - has the update been released, and if so how does one do the update?
Thanks.
tester
Which thermostats work with RaZberry?
Post by tester »
We are having the same problems noted above with the CT100 and CT30 thermostats (changing heat or cool setpoints do not work - only changing mode works) [using the latest wget update for RaZberry]. It seems that only the old (and no longer available) Wayne Dalton WDTC-20 (also known as CA8900) work. This leads to a very simple question - which thermostats available today actually work with the RaZberry? [Using the latest update on the RaZberry.]
We have been waiting for a solution for sometime, and would appreciate some type of meaningful and useful response.
tester
Thermostats work with Control Think USB stick
Post by tester »
We tested the same thermostats- IS-ZW-TSAT-100, CT100 and CT30 - with the ControlThink USB stick connected to a PC and they worked fine. So the thermostats are not the problem, but it is the RaZberry hardware/firmware that does not work properly.
Please try our latest 1.4
