I'm new to this forum. I've been using RaZberry with Z-Wave for a couple of weeks now and it works great. So far this forum has provided all the answers I needed to get my problems solved. Unfortunately, I couldn't find any hints to my current problem.
I managed to include quite a few devices in my Network but now I'm struggling to get my new Fibaro Heat Controller FGT-001 working. The Interview always completes most of the command classes. Nevertheless, the CommandClass "Security" in instance 1 and 2 won't complete. Resetting the device to factory defaults didn't help. Does anyone have a solution to this issue?
Fibaro heat controller / thermostat FGT-001
- Unbenannt.PNG (80.83 KiB) Viewed 27967 times
Re: Fibaro heat controller / thermostat FGT-001
The log says:
Node 30:1 CC Security: secure channel not established on root device - can not interview inside channel
Try to make Insecure Inclusion. Works most of the times with Fibaro devices
I've tried secure and insecure inclusion multiple times. Both didn't finish completely.
I have the same problem. Anyone solved it?
Try to update to 3.0.0.
After adding device wait for the window to appear. Enter pin code. Device should be added with security s2.
try to be closer to razzbery (max 2m) with fibaro device during inclusion. In ma case it helps.
Preetisharma
- Contact:
Excellent thread! Thank you!
