Fibaro Dimmer 2, duplicate devices!!
Lilchamp
Post by Lilchamp »
I have just recently installed some Fibaro Dimmer 2 (FGD-212) units. When adding them as a new device, each dimmer ends up with a whole heap of "devices" (I'm running Z-Way 2.3.6). One example gives me all the following:
- Fibaro Dimmer 2
- Current consumption (26.1)
- Fibaro Dimmer (26.1)
- Fibaro Dimmer (26.2)
- Fibaro Heat Alarm (26.1)
- Fibaro Power Management Alarm (26.1)
- Fibaro System Alarm (26.1)
- Total consumption (26.1)
I understand the various names, and that there has to be two "Fibaro Dimmer" devices (because you can use two switches with the dimmer, 26.1 and 26.2), but why is there so many duplicate alarm devices? Can I disable all duplicates?
I found the same question in the Russian forum (viewtopic.php?t=25354), but as I don't speak the language, and Google Translate wasn't too helpful, I was hoping somebody could help me out here as well!
Top
Re: Fibaro Dimmer 2, duplicate devices!!
Fibaro produces many Power Management alarms like undervoltage, overvoltage, ... Looks Z-Way is not naming them correctly. Expert UI should show them as different event types
