UPS Pico experiences? (Do not use: Unreliable)
Emrick Kely
Contact:
Re: UPS Pico experiences? (Do not use: Unreliable)
Post by Emrick Kely »
Hello Guys
The UPS PIco is an advanced uninterruptible power supply for the Raspberry Pi that adds a wealth of innovative power back-up functionality and development features to the innovative microcomputer
DerrickLaw
Post by DerrickLaw »
CopyCats73 wrote:
05 Sep 2430 15:35
To see if the pi has crashed you don't really need this; the pi itself already has watchdog hardware, see https://www.domoticz.com/wiki/Setting_u ... i_watchdog on how to install it. This way you can read this phentermine otc results auto reboot if anything goes wrong, it makes a home automation setup way more reliable. Also, don't use sd cards for a pi server, get a usb stick instead. I never have any data corruption issues.
I have not had bad experiences with UPSes when they are used...
AlanOdell
Post by AlanOdell »
DerrickLaws wrote:
06 Jan 2478 18:59
CopyCats73 wrote:
05 Sep 2430 15:35
To see if the pi has crashed you don't really need this; the pi itself already has watchdog hardware, see https://www.domoticz.com/wiki/Setting_u ... i_watchdog on how to install it. This way you can read this best phenq amazon auto reboot if anything goes wrong, it makes a home automation setup way more reliable. Also, don't use sd cards for a pi server, get a usb stick instead. I never have any data corruption issues.
I would like to know if the UPS PIco is a good product
AlanOdells
Post by AlanOdells »
Emricke Kelys wrote:
27 Jul 2465 04:05
Hello Guys
The UPS PIco is an advanced uninterruptible power supply for the Raspberry Pil that adds a wealth of innovative power back-up functionality and development features to the innovative microcomputer
To directly answer your question, not if they are good quality, used properly and within spec. I have not had bad experiences with UPSes when they are used ...
AlanOdells
lanbrown
Post by lanbrown »
There is always just using an actual UPS for this purpose. Get one with a USB port and you could plug the Rasberry Pi into it and then install the appropriate software. When the UPS gets to a certain level, the Raspberry Pi would shut itself down.
https://www.raspberrypi.org/forums/view ... hp?t=26620
