yale keyless connected not reporting status
lanbrown
Re: yale keyless connected not reporting status
Post by lanbrown »
The 4.1.4 is the Z-Way software version, the 5.04 is the firmware on the Razberry card. Upgrading Z-Way does not upgrade the firmware on the Razberry board.
seattleneil
Post by seattleneil »
The log snippet provides useful information. You'll need to do additional testing to see what messages the lock sends when it's manually locked and unlocked.
Based on the log information you provided, the Easy Scripting app should be able to solve your problem. The Easy Scripting app is very useful and powerful. It lets you write JavaScript code to listen for Z-Wave messages from a device/command class and then take an action. When I want to do complex if/then logic, the Easy Scripting app is what I use. Note that the app needs to be used carefully since it runs in the main Z-Way processing thread - a poorly written app can destabilize your entire Z-Way setup. If that happens, just stop the Easy Script app. With that warning out of the way, let's make progress.
The log shows:
[10:01:19] INFO: [2024-12-19 10:01:19.156] [I] [zway]  Node 25:0 CC Security: passing decrypted packet to application level: [ 71 05 13 fb ]
[10:01:19] INFO: [2024-12-19 10:01:19.156] [D] [zway]  SETDATA devices.25.instances.0.commandClasses.113.data.V1event.alarmType = 19 (0x00000013)
[10:01:19] INFO: [2024-12-19 10:01:19.156] [D] [zway]  SETDATA devices.25.instances.0.commandClasses.113.data.V1event.level = 251 (0x000000fb)
[10:01:19] INFO: [2024-12-19 10:01:19.156] [D] [zway]  SETDATA devices.25.instances.0.commandClasses.113.data.V1event = Empty
Assuming your lock (device 25) sends an alarm message (command class 113) with alarmType=18 or 21 when the door is locked and alarmType=19 or 22 when the door is unlocked, something like the following Easy Scripting code should work:
### ZWayVDev_zway_25-0-113
console.log("In Easy Scripting App - alarmType, level:", vdev("ZWayVDev_zway_25-0-113").V1event.alarmType.value(),vdev("ZWayVDev_zway_25-0-113").V1event.level.value());
if (vdev("ZWayVDev_zway_25-0-113").V1event.alarmType.value() == "18" || vdev("ZWayVDev_zway_25-0-113").V1event.alarmType.value() == "21") {
     vdev("ZWayVDev_zway_25-0-113").set("metrics:level", "close")
if (vdev("ZWayVDev_zway_25-0-113").V1event.alarmType.value() == "19" || vdev("ZWayVDev_zway_25-0-113").V1event.alarmType.value() == "22") {
     vdev("ZWayVDev_zway_25-0-113").set("metrics:level", "open")
Since I don't have a Yale lock, you'll need to test/debug the Easy Script app. If you get stuck, please post the z-way-server log file that shows what happens when you manually lock and unlock the door.
doubledrat
Post by doubledrat »
thanks. if I can work out how to get into easy scripting, I'll give it a go!
