Fibaro Wall Plug AlarmSensor
kickus
Re: Fibaro Wall Plug AlarmSensor
Post by kickus »
I've got the same problem with failing AlarmSensor interview.
Is it serious, can it affect the functionality of the rest of my z-wave network? The Fibaro wall plug seems to function quite well, regardless of that partly failing interview.
Of course any misbehavior should be corrected by Fibaro, but I'm curious whether this can relate to problems with my other devices. Is there any temporary work around?
hkoopmans
Post by hkoopmans »
I have both sensors. The older ones with the alarm sensor interview failure and newer ones with newer firmware without the failure. Both work fine. Never encountered problems with the old ones. Seems that the interview failure does not affect the functionality.
