Danfoss Living Connect
aspliid
sent
Post by aspliid »
I have sent the clips to your info email.
aspliid
MultiCmd bug
Post by aspliid »
Hi!
Just curious: what's the status with the MultiCmd bug?
Fixed
Dear aspliid,
Should be fixed now. Please let me know if you still experience same problem.
It was quite hard to reproduce, since it seems to be due to bad Internet connection.
newtonehv
Danfoss living connect thermostat feedback?
Post by newtonehv »
I'm curious to know if it's possible the get any feedback from the thermostat? I'd like to know the actual room temperature or whether or not the valve is open. It would be quite expensive to buy a separate temperature sensor for each room...
With this information I want to switch on and off my central heating. In the future, It would be nice to modulate the heating using Opentherm..
Grz.
Unfortunately Danfoss Living Connect do not report actual temp
And there is no way to know if the valve is open neither.
In contrast, Horstmann thermostat have the ability to report current temperature if configured approprietary.
Soepkip
Poltos, are you able to tell
Post by Soepkip »
Poltos, are you able to tell me more about the horstmann thermostat in zcloud? I am about to receive this thermostat and would like to control it from zcloud!
Horstmann HRT4-ZW thermostat is fully supported by Z-Way/Z-Cloud
Reply is posted in a separate thread dedicated to Horstmann HRT4-ZW.
pallegd
Problems with the climate schedule
Post by pallegd »
Hi there,
I have added two Living Connect thermostats, included them in a zone, and create a climate schedule for the zone. So far so good.
I can change the set points of the thermostats by the "cooler/warmer" (they are in automatic control). But the climate schedule does not seem to work. It seems that the set point of the thermostats are not changed at the time of change in the climate schedule. The temperature reading both under "device control" and on the read-out display on the actual thermostats remains the same 24/7. What may I have done wrong?
Thanks otherwise for a very intuitive and easy to use system!
pallegd
Please disregard
Post by pallegd »
Please disregard the above message. Turns out the thermostats were not properly included in a zone and hence did not react to the climate schedule.
pallegd
The story continues
Post by pallegd »
hm. Now it seems I have encountered the next hurdle: Now, everything seems to be controlled by the climate schedule. In "Device control -> Thermostats" all thermostats reports 22 deg C in accordance with the schedul. BUT: the display on the actual thermostats says 18 deg C on all of them. At first, I thought that this was OK in accordance with a previous post (something about showing only SetPoint, not SetPoint + SetBack), BUT the radiators have all gone cold, and the room temperature has dropped to 19 (as measured with a thermometer).
Have switched back to manual control (not to upset the wife too much) for now. Any help on this greatly appreciated!
