Energy Management like Aeon-Labs Home Energy Monitor 2
jorisdekloris
Post by jorisdekloris »
First let me say Z-Cloud rocks. It's easy, cheap and does the work.
Is it possible to use Aeon-Labs Home Energy Monitor 2 with Z-Cloud? Or do i have to use something else to measure my energy consumption?
Sure, you can.
It should work out of the box and report metering values upon request. Make sure to have a stick based on 5.0x SDK (any) or on 4.5x SDK with FLiRS support.
jorisdekloris
How
How can i check the SDK version of my stick?
ihagon
turn on expert mode and
Post by ihagon »
turn on expert mode and select "for experts" then "Controller Info" it's in there
jorisdekloris
I've checked my SDK version and its 5.0.x
This means that you can use HEM with no problems
Have you tried?
jorisdekloris
No
No i havent. I'm still searching for a device that can monitor my gass usage.
Consider NorthQ metering device.
It can monitor gas too!
jorisdekloris
thanks
I will look into that. Do you mean this?
http://northq.com/products/zwave/nq92021.html
