Need help configuring hold button to dim up/down
erikst
Post by erikst »
I have the Merten CONNECT Z-wave system, 2-gang push buttons and Universal flush-mounted 250 VA dimmer.
When configuring with z-wave, I can't get the push buttons to dim the switches. The push buttons only turn the switches on or off, no dimming.
Does anyone know how to configure this?
Best regards
Erik
Unfortunatelly we have no such device to make tests.
But in general you have to configure parameter 0 in your device. Have a look in the manual or on http://pepper1.net/zwavedb/device/69.Also note that this device violates Z-Wave standarts and uses parameter number 0. They should start from 1. This can lead to impossibility to configure it with Z-Way/Z-Cloud.
Mowitz
I have the exact same problem
Post by Mowitz »
I have the exact same problem. Did you find a solution?
According to the link above, parameter 0 is for switching/dimming/shutters. How do I know which value to set for dimming. I assume it's 1, i.e. 0 for switching, 1 for dimming and 2 for shutters? Is that correct?
Thanks!
