CT30 Thermostat problem
gdselzer
Post by gdselzer »
I am having problems with getting a  CT30 thermostat to work as I want.  I feel I should disclose the distinct possibility that I do not fully understand the Climate control in Zway.
When I set the Thermostat to Manual in Zway and control the Set Temp using just the interface on the thermostat itself, all works as expected.  If I set Zway to control the thermostat the temp shown in "Device Control">Thermostats does not match what I put in the Climate Schedule. Further, it is showing the Temperature in Fahrenheit, even though the CT30 is showing Celsius and the Climate Schedule is set in Celsius. I put 20 degrees C in the Climate Schedule, but the Thermostat info says "67 grd F" for the Maintained Temp and "(20+47)" for the calculated temp.    When in Automatic mode, if I try to adjust the temp up or down the display momentarily shows the correct information in red 25 and (20+5), but then quickly goes back to 67 and stays there. The Target Temp on the thermostat goes to 01.5 degrees when I try to make adjustments from Zway.
When watching the log file, I do not see anything odd. It reports that the temp changes have been set. Am I doing something wrong?
It seems that Z-Way have some
It seems that Z-Way have some problems with F units - it assumes temperture is in C. We have tried only once to test Z-Way against US thermostat and it worked, so it is strange that this one does not. A debug log might reveal the problem.
e-nando
Same problem with a CT100
Post by e-nando »
I have the same problem with a CT00 Thermostat (US). The temperatures are correctly shown in Z-Way in deg. C, but the thermostat needs to be set in deg. F and Z-Way sends the temp in deg. C. The thermostat simply ignores the deg. C values as they're below the min for the thermostat.
Need a setting in Z-Way to force sending temperatures in deg. F to the thermostat.
Thanks!
This problem is fixed in our
This problem is fixed in our internal beta. This beta will be published next week and become release by the begining of august
dpmcgarry
Fix?
Post by dpmcgarry »
When is this fix getting released? It's almost September now...
The beta v1.4-rc1 is out for
The beta v1.4-rc1 is out for quite some time, but will become stable after we fix some problems in it.
dpmcgarry
Is it possible for me to
Post by dpmcgarry »
Is it possible for me to download the beta to try it out? Where can I get it?
Now v1.4 is out - upgrade
Now v1.4 is out - upgrade your s/w.
http://en.z-wave.me/content/new-version ... y-released
