I can't seem to get the lock to include in Z way. I ask the software to include a new device and then I press the connect button on the lock but the light doesn't turn yellow (according to the lock instructions that is supposed to happen)
Am I doing something wrong or is the lock bad?
Here is the log...
2013-06-17 17:29:01.203] Job 0x4b: deleted from queue
[2013-06-17 17:29:01.240] Job 0x4b: deleted from queue
[2013-06-17 17:29:01.253] Job 0x4a (Add/re-include node to network): Job not removed before timeout (awaiting for more callbacks?)
[2013-06-17 17:29:01.256] Job 0x4a (Add/re-include node to network): Cancelling
[2013-06-17 17:29:01.258] Job 0x4a (Add/re-include node to network): fail
[2013-06-17 17:29:01.260] Adding job: Add/re-include node to network
[2013-06-17 17:29:01.273] SENDING (cb 0xc5): ( 01 04 00 4A C5 74 )
[2013-06-17 17:29:01.290] RECEIVED ACK
[2013-06-17 17:29:01.292] Removing job: Add/re-include node to network
[2013-06-17 17:29:01.337] RECEIVED: ( 01 07 00 4A 1A 06 00 00 AE )
[2013-06-17 17:29:01.344] SENT ACK
[2013-06-17 17:29:01.345] Job 0x4a (Add/re-include node to network): Done
[2013-06-17 17:29:01.347] SETDATA controller.data.controllerState = 0 (0x00000000)
[2013-06-17 17:29:01.348] Removing job: Add/re-include node to network
Hobs
Unable to include Kwikset lock
Please tell us how you did it
Please tell us how you did it so others can learn from your experience
