Z.Wave.me Wall Controller
ollie
Post by ollie »
I am trying to use the z.wave.me battery powered wall controller... So far little success, I manage to include, but interview is not completed and I am unable to do any association. I am using a Razberry controller & Z-Way.
Thanks for your help.
Are you sure the device is
Are you sure the device is included using correct button sequence? May be you ar using wakeup sequence?
ollie
Post by ollie »
I was expecting setting up the association through the Razberry and not using the wall controller. Thanks for the direction ! Seems to work fine now, the Fibaro micro module is associated to the wall controller.
