Z.Wave.me Wall Controller
Posted: 29 Sep 2013 00:52
by ollie
I am trying to use the z.wave.me battery powered wall controller... So far little success, I manage to include, but interview is not completed and I am unable to do any association. I am using a Razberry controller & Z-Way.
Thanks for your help.
Are you sure the device is
Are you sure the device is included using correct button sequence? May be you ar using wakeup sequence?
by ollie
I was expecting setting up the association through the Razberry and not using the wall controller. Thanks for the direction ! Seems to work fine now, the Fibaro micro module is associated to the wall controller.
