FIBARO RGBW Controller
Did anyone get the FIBARO RGBW Controller (FGRGBWM-441) to work with z-way?
Works out of the box as 4
Works out of the box as 4 dimmers
RGBW Dimmer Problem: can't find the correct config.xml
yesterday I got my new RGBW and Dimmer from Fibaro. I managed to include both devices but the RGBW Modul seeems to be broken. The Device is in online mode but I can't change the states!! What configure (XML) filde did you choose? would be great to get help..
Thanks!
Thanks!
The config params are not
The config params are not loaded to the Pepper1 db yet, but you can use Expert Commands with the device manual
