I have a sensor which can measure humidity, luminescence and temperature. It has device ID 3.
When requesting: http://localhost:8083/ZWaveAPI/Run/devi ... nstances[0] it returns json data which i have uploaded to the following link:
http://pastebin.com/R1iWq3VT
The value I am looking for resides in commandClass 49. Under this class, there is a variable (or class?) called 3. The "val" attribute in 3 holds the luminescence which is 1000.
I have tried various ways to construct a URL to retrieve this value but can't get it right.
What should the URL look like?
How to get luminescence from a sensor through ZWaveAPI?
Re: How to get luminescence from a sensor through ZWaveAPI?
From the top of my head I would say:
http://localhost:8083/ZWaveAPI/Run/devi ... .val.value
I am a bit in doubt about the val.value part
It works!
Thanks alot
Thanks alot
good!
On my Windows7 machine I use the text editor notepad++ in which you can install a JSON browser. That gives a graphical view of the JSON blurb. Helped me a lot to understand these structures.
