AEON LABS HEM3 G2
Posted: 11 Sep 2014 18:00
by martinisonline
After a successful inclusion of this device, i'm having a 'small' problem.
The voltage reported by the device is incorrect and in consequence the Wattage and Energy measurements are also wrong.
If I connect all phases together in parallel, I get around 57volt on each. If I connect only phase 3, I get around 116V. In both situations the correct voltage should be ~230V.
Should i need to make any configuration in order to get the correct values?
BR,
