Aeon Labs AEOTEC Range Extender Offline Detection
enco.josh
Post by enco.josh »
Up to this point, I have been using only battery powered devices. I am able to detect that battery powered devices have dropped offline by looking at their lastWakeup property and their check in interval. How can I detect that a powered device is offline or online? I could poll the device, but the range extender doesn't have much to poll. Do the isAwake, isListening, isFailed properties update automatically or is this something that I would have to poll?
Here is the JSON object for the device.
{"instances":{"0":{"commandClasses":{"32":{"name":"Basic","data":{"invalidateTime":1412969289,"updateTime":1412967457,"type":"NoneType","name":"devices.54.instances.0.commandClasses.32.data","value":null,"supported":{"invalidateTime":1412969289,"updateTime":1412967457,"type":"bool","name":"supported","value":true},"version":{"invalidateTime":1412969289,"updateTime":1412967457,"type":"int","name":"version","value":1},"security":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"security","value":false},"interviewDone":{"invalidateTime":1412967456,"updateTime":1412967463,"type":"bool","name":"interviewDone","value":true},"interviewCounter":{"invalidateTime":1412967456,"updateTime":1412967462,"type":"int","name":"interviewCounter","value":9},"level":{"invalidateTime":1412969288,"updateTime":1412969289,"type":"int","name":"level","value":0}},"id":32},"112":{"name":"Configuration","data":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"NoneType","name":"devices.54.instances.0.commandClasses.112.data","value":null,"supported":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"supported","value":true},"version":{"invalidateTime":1412967457,"updateTime":1412967459,"type":"int","name":"version","value":1},"security":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"security","value":false},"interviewDone":{"invalidateTime":1412967456,"updateTime":1412967462,"type":"bool","name":"interviewDone","value":true},"interviewCounter":{"invalidateTime":1412967456,"updateTime":1412967462,"type":"int","name":"interviewCounter","value":9}},"id":112},"114":{"name":"ManufacturerSpecific","data":{"invalidateTime":1412967460,"updateTime":1412967457,"type":"NoneType","name":"devices.54.instances.0.commandClasses.114.data","value":null,"supported":{"invalidateTime":1412967460,"updateTime":1412967457,"type":"bool","name":"supported","value":true},"version":{"invalidateTime":1412967460,"updateTime":1412967459,"type":"int","name":"version","value":2},"security":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"security","value":false},"interviewDone":{"invalidateTime":1412967456,"updateTime":1412967461,"type":"bool","name":"interviewDone","value":true},"interviewCounter":{"invalidateTime":1412967456,"updateTime":1412967460,"type":"int","name":"interviewCounter","value":9},"vendorId":{"invalidateTime":1412967460,"updateTime":1412967461,"type":"int","name":"vendorId","value":134},"vendor":{"invalidateTime":1412967460,"updateTime":1412967461,"type":"str","name":"vendor","value":"Aeon Labs"},"productId":{"invalidateTime":1412967460,"updateTime":1412967461,"type":"int","name":"productId","value":37},"productType":{"invalidateTime":1412967460,"updateTime":1412967461,"type":"int","name":"productType","value":4}},"id":114},"115":{"name":"PowerLevel","data":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"NoneType","name":"devices.54.instances.0.commandClasses.115.data","value":null,"supported":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"supported","value":true},"version":{"invalidateTime":1412967457,"updateTime":1412967459,"type":"int","name":"version","value":1},"security":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"security","value":false},"interviewDone":{"invalidateTime":1412967456,"updateTime":1412967463,"type":"bool","name":"interviewDone","value":true},"interviewCounter":{"invalidateTime":1412967456,"updateTime":1412967462,"type":"int","name":"interviewCounter","value":9},"level":{"invalidateTime":1412967462,"updateTime":1412967463,"type":"int","name":"level","value":0},"timeout":{"invalidateTime":1412967462,"updateTime":1412967463,"type":"int","name":"timeout","value":0}},"id":115},"133":{"name":"Association","data":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"NoneType","name":"devices.54.instances.0.commandClasses.133.data","value":null,"supported":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"supported","value":true},"version":{"invalidateTime":1412967457,"updateTime":1412967459,"type":"int","name":"version","value":1},"security":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"security","value":false},"interviewDone":{"invalidateTime":1412967456,"updateTime":1412967463,"type":"bool","name":"interviewDone","value":true},"interviewCounter":{"invalidateTime":1412967456,"updateTime":1412967462,"type":"int","name":"interviewCounter","value":9},"groups":{"invalidateTime":1412967462,"updateTime":1412967463,"type":"int","name":"groups","value":1},"1":{"invalidateTime":1412967463,"updateTime":1412967464,"type":"NoneType","name":"1","value":null,"max":{"invalidateTime":1412967463,"updateTime":1412967464,"type":"int","name":"max","value":5},"nodes":{"invalidateTime":1412967463,"updateTime":1412967464,"type":"binary","name":"nodes","value":[1]}}},"id":133},"134":{"name":"Version","data":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"NoneType","name":"devices.54.instances.0.commandClasses.134.data","value":null,"supported":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"supported","value":true},"version":{"invalidateTime":1412967457,"updateTime":1412967459,"type":"int","name":"version","value":1},"security":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"security","value":false},"interviewDone":{"invalidateTime":1412967456,"updateTime":1412967459,"type":"bool","name":"interviewDone","value":true},"interviewCounter":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"interviewCounter","value":9},"ZWLib":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"int","name":"ZWLib","value":6},"ZWProtocolMajor":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"int","name":"ZWProtocolMajor","value":3},"ZWProtocolMinor":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"int","name":"ZWProtocolMinor","value":67},"SDK":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"str","name":"SDK","value":"4.55.00"},"applicationMajor":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"int","name":"applicationMajor","value":1},"applicationMinor":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"int","name":"applicationMinor","value":6},"hardwareVersion":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"NoneType","name":"hardwareVersion","value":null},"firmwareCount":{"invalidateTime":1412967458,"updateTime":1412967459,"type":"int","name":"firmwareCount","value":0}},"id":134}},"data":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"NoneType","name":"devices.54.instances.0.data","value":null,"dynamic":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"dynamic","value":false},"genericType":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"genericType","value":15},"specificType":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"specificType","value":1}},"id":0}},"data":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"NoneType","name":"devices.54.data","value":null,"basicType":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"basicType","value":4},"genericType":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"genericType","value":15},"specificType":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"specificType","value":1},"infoProtocolSpecific":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"infoProtocolSpecific","value":13868032},"deviceTypeString":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"str","name":"deviceTypeString","value":"Repeater Slave"},"isVirtual":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"isVirtual","value":false},"isListening":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"isListening","value":true},"isRouting":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"isRouting","value":true},"isAwake":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"isAwake","value":true},"optional":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"optional","value":true},"isFailed":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"isFailed","value":false},"beam":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"beam","value":false},"sensor250":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"sensor250","value":false},"sensor1000":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"bool","name":"sensor1000","value":false},"neighbours":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"binary","name":"neighbours","value":[1]},"manufacturerId":{"invalidateTime":1412967456,"updateTime":1412967461,"type":"int","name":"manufacturerId","value":134},"vendorString":{"invalidateTime":1412967456,"updateTime":1412967461,"type":"str","name":"vendorString","value":"Aeon Labs"},"manufacturerProductType":{"invalidateTime":1412967456,"updateTime":1412967461,"type":"int","name":"manufacturerProductType","value":4},"manufacturerProductId":{"invalidateTime":1412967456,"updateTime":1412967461,"type":"int","name":"manufacturerProductId","value":37},"ZWLib":{"invalidateTime":1412967456,"updateTime":1412967459,"type":"int","name":"ZWLib","value":6},"ZWProtocolMajor":{"invalidateTime":1412967456,"updateTime":1412967459,"type":"int","name":"ZWProtocolMajor","value":3},"ZWProtocolMinor":{"invalidateTime":1412967456,"updateTime":1412967459,"type":"int","name":"ZWProtocolMinor","value":67},"SDK":{"invalidateTime":1412967456,"updateTime":1412967459,"type":"str","name":"SDK","value":"4.55.00"},"applicationMajor":{"invalidateTime":1412967456,"updateTime":1412967459,"type":"int","name":"applicationMajor","value":1},"applicationMinor":{"invalidateTime":1412967456,"updateTime":1412967459,"type":"int","name":"applicationMinor","value":6},"nodeInfoFrame":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"binary","name":"nodeInfoFrame","value":[32,112,114,133,115,134]},"ZDDXMLFile":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"str","name":"ZDDXMLFile","value":null},"lastSend":{"invalidateTime":1412967456,"updateTime":1412969289,"type":"int","name":"lastSend","value":426429},"lastNonceGet":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"lastNonceGet","value":263207},"lastReceived":{"invalidateTime":1412967456,"updateTime":1412969289,"type":"int","name":"lastReceived","value":0},"failureCount":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"failureCount","value":0},"keepAwake":{"invalidateTime":1412967456,"updateTime":1412967464,"type":"bool","name":"keepAwake","value":false},"countSuccess":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"countSuccess","value":0},"countFailed":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"countFailed","value":0},"queueLength":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"int","name":"queueLength","value":0},"givenName":{"invalidateTime":1412967456,"updateTime":1412967457,"type":"str","name":"givenName","value":null}},"id":54}
Re: Aeon Labs AEOTEC Range Extender Offline Detection
these three values comes from the protocol. No need to test them
enco.josh
Post by enco.josh »
I left the repeater unplugged over the weekend and checked the values this morning.
isAwake = true
isListening = true
isFailed = false
All of the values are the same as when the device was plugged in. How can I detect if the device is operating correctly or not?
See if the values in the routing table in blue interface are different with and without the extender.
enco.josh
Post by enco.josh »
That is a possibility, but if the range extender is expanding the network to reach a device that couldn't reach the controller otherwise, the routing table would not change at all. Is there a property on the controller or on the device itself that I can check to see if it is offline or not.
