Fibaro MultiSensor FGMS-001 V2.6 problems
Posted: 05 Dec 2014 13:59
by hpd
Fibaro Multisensor is not proberly working.
- Included the device in Razberry.
- Inclusion completed but could not identify the correct description file
- Attached the description file manually
- The device appears in the "devices" list, but not in the "Sensor" list
- Configuration ui says "Invterview not completed yet..."
- Tried to "force reinterview"
- still the same! no sensor values shown
Anything further I can try with this sensor to get it working in zway.
I am currently using rc24
Re: Fibaro MultiSensor FGMS-001 V2.6 problems
Posted: 06 Dec 2014 13:25
by hpd
Excluded device. Recincluded it. Works perfectly OK now
Posted: 09 Dec 2014 01:14
by hpd
in RC31 Configuration of this device is not possible. Most parameter values are not correctly shown. eg Parameter 42 shows 32769 and can not be changed.
Posted: 09 Dec 2014 03:03
by hpd
Again i am a victim of the misconfigured ZDDX FIles for Fibaro devices. Many parameters have wrong set ups and are therefore misinterpreted by the configuration ui.
I changed this in the ZDDX Files.
Zway Team, Please arrange these files to be corrected. We all lose so much time and confidence in your product if you can not get this fixed.
Posted: 25 Dec 2014 16:44
by da2001
Hello hdp,
I also can't get it worked correctly.
Can you please help me with the modification of the Zddx file?
Maybe, if possible, you Van Upload the file. It would help me a lot.
Best wishes
Posted: 03 Jan 2015 00:18
by timb
I am new to all of this. I wasted 2 days trying to configure this device. I put the settings in, but the UI kept changing them e.g. Motion sensor cancellation 32767 - every time I entered 30 and moved to the next field it reverted to 32767. At first I thought the Expert UI must be full of bugs. It wasn't until I discovered the Expert Commands I found I could actually make some values stick. Eventually I came to the forums and to my frustration and delight I saw others had the same issue. Is there any way of getting updated Zddx files? And if I get them how do i install them? Many thanks.
