Hello
I wonder if anyone has any idea how I can do the following.
I have this pir in my bathroom now so when I enter the light turns on and when I leave it turns off, it's a 2 wire uk system.
http://www.ebay.co.uk/itm/Wall-Light-Sw ... 35e30d8d44
The pir takes the place of a pull switch which I removed so there is no other switch.
How can I add a fibaro dimmer to this setup ?
I have a razberry on order and I wish to set a time between 9pm and 6am that if I enter, the lights only dim to half and then later dim all the way up, I can work out the automation my self or later but am not sure of the wiring of the fibaro or if it's even possible.
