Schlage Model BE469 support
Posted: 10 Feb 2015 23:59
I have my Schlage Model BE469 included in the network and functioning... to some degree. I am able to lock and unlock it. It appears that people are having different degrees of success with connecting this lock.
Since (in my install) there is not the option for selecting the correct lock model in the "Select device Description" I have tried a number of different choices with different degrees of success.
Does anyone know if there is a way to select the correct or a better XML config file?
I have the Schlage Model BE469 Config parameter document and I have started to see if I can create my own. Has anyone else had success with this?
One of the threads in this forum seems to imply that they were able to get to the code config section of the lock but didn't identify which XML file they used.
Thanks for any suggestions that can be provided.
