danalock won't connect
iliggio
Post by iliggio »
Hi, has anyone experience with the danalock? If I turn on the inclusion mode, nothing happens (i did the steps in the description of danalock)
Has anyone got any idea about possible error source?
Here the part of the log:
[2015-04-10 19:52:36.314] [zway] Adding job: Add/re-include node to network
[2015-04-10 19:52:36.315] [D] [zway] SENDING: ( 01 04 00 4A 05 B4 )
[2015-04-10 19:52:36.318] [D] [zway] RECEIVED ACK
[2015-04-10 19:52:36.320] [zway] Removing job: Add/re-include node to network
[2015-04-10 19:52:36.369] [D] [zway] RECEIVED: ( 01 07 00 4A 02 06 00 00 B6 )
[2015-04-10 19:52:36.370] [D] [zway] SENT ACK
[2015-04-10 19:52:36.372] [zway] Job 0x4a (Add/re-include node to network): Done
[2015-04-10 19:52:36.373] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2015-04-10 19:52:36.374] [zway] Removing job: Add/re-include node to network
[2015-04-10 19:52:56.431] [D] [zway] Job 0x4a: deleted from queue
Quax1507
Re: danalock won't connect
Post by Quax1507 »
Hi Liliggio,
I had a Danalock BTZE100 and successfully included it in Z-Way Server v2.0.1-rc24.
But I sent it back because it was incredibly slow with my front door :(
Quax1507
Make sure you have Z-Wave capable Danalock (they have BT version only)
Quax1507
Post by Quax1507 »
That's right, PoltoS!
But they even have different Versions with Z-wave on board!
I ordered one and found out, it did not have "Türfalle" which is necessary in Germany...
marco
Post by marco »
in my recent experience with a danalock inclusion in a z-wave network it seems that the problem with this device is the distance from the router. Up to 2 meters distance it seems that everythings work properly. From 2 meters the device goes lost. Actually, bypassing the problem of range, at the moment I'm studing why it does not use a neighbour device to route in the mesh.
Marco
