Roller Shutter as switch and not as dimmer:(
Posted: 14 Jun 2015 21:34
hi, i have this roller shutter: Fibaro Roller Shutter 2 FGRM-222 but when i try to recognise it with z-wave it become a switch sensor, so i have only the choice to set on and off....and i could not select up and down...and i could not set the percentage of opening/close
the percentage of opening/closing is only possible to set using:
expert mode -> configuration -> commands and finally set dimmer level
and it works fine....but how i could change from switch sensot to dimmer sensor, just to have the correct icons?
thanks
thanks
