ZME_05461 Dual Load Wall Switch
Posted: 03 Jul 2015 01:53
by x3ntor
Hi! My new zwave.me ZME_05461 Dual Load Wall Switch is detected in ZWay 2.0 (on RaspberryPi) as Motor Control Device.
But i don't want to control blinds...i want to switch my lights on and off. What can i do? Any ideas?
Re: ZME_05461 Dual Load Wall Switch
Posted: 05 Jul 2015 02:22
Could you please show manufacturer ID / product ID/ product type ID?
Posted: 07 Jul 2015 01:03
by x3ntor
I hope these are the right informations:
commandClass
/:None (04.07.2015)
supported: true (04.07.2015)
version: 1 (04.07.2015)
security: false (04.07.2015)
interviewDone: true (04.07.2015)
interviewCounter: 9 (04.07.2015)
vendorId: 277 (04.07.2015)
vendor: Z-Wave.Me (04.07.2015)
productId: 3 (04.07.2015)
productType: 4096 (04.07.2015)
serialNumber: None (04.07.2015)
Posted: 07 Jul 2015 02:55
Hm... seems you indeed got a blind control device instead of double switch. Could you please check labeling on the device and box if it should be a Double switch and not a Blind control? I doubt there was a manufacturing problem. Looks more like "box mix" problem - some one mixed boxes.
Posted: 08 Jul 2015 14:51
by x3ntor
Ok, i'll check the label on the device, when i'm back at home.
The label on the box says: ZME 05461
Is it possible to flash the switch-firmware on the blind-control device
by myself? Because i think those two devices are the same REV-Ritter devices but with other firmwares?!?
Or should i contact my dealer, that he should replace the device with the correct one?
Or is there a special zwave.me contact partner in germany?
Posted: 09 Jul 2015 00:38
You can not flash them yourself. Requires special programmer, firmware and there is a minor h/w change (bigger capacity to allow switching both relays together)
Please contact your dealer. Please contact Z-Wave Europe as our main partner or your supplier
