1. Jobs queue looks like
U W S E D Ack Resp Cbk Timeout NodeId Description Progress Buffer
0 W - - - 0.20 3 SensorBinary Get 3 2 30 2 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 1 0 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 3 8 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 5 0 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 1b 0 5
0 W - - - 0.20 3 Alarm Get (v3) 3 5 71 4 0 7 0 5
Queue length: 6Code: Select all
[2015-12-05 15:00:00.259] [I] [core] --- ZWayVDev_zway_3-0-48-1 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.260] [D] [zway] Job 0x13 (SensorBinary Get): removing duplicate
[2015-12-05 15:00:00.261] [I] [core] --- ZWayVDev_zway_3-0-49-1 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.263] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.263] [I] [core] --- ZWayVDev_zway_3-0-49-3 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.264] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.265] [I] [core] --- ZWayVDev_zway_3-0-49-5 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.265] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.265] [I] [core] --- ZWayVDev_zway_3-0-49-27 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.266] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.266] [I] [core] --- ZWayVDev_zway_3-0-113-7-3-A performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.267] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicate
[2015-12-05 15:00:00.268] [I] [core] --- ZWayVDev_zway_3-0-113-7-8-A performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.269] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicateexpert/#/control/sensors-page that lists all sensors shows that the last update has been made at 14:39. I guess when the timeout at 20 has passed the entries in the log will be removed and the sensors updated when next 10min is triggered? But now the log shows:
[2015-12-05 15:20:00.708] [I] [core] --- ZWayVDev_zway_3-0-48-1 performCommand processing: {"0":"update"}
[2015-12-05 15:20:00.709] [D] [zway] Job 0x13 (SensorBinary Get): removing duplicate
2. Configuration settings are not stored according to the expert/configurations page
Configuration Settings
Nº 3 - default PIR time: Value was changed to 0 but not stored in device yet.
Nº 5 - command sent when the motion sensor triggered.: Value was changed to 0 but not stored in device yet.
Nº 41 - Threshold change in temperature to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 42 - Threshold change in humidity to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 43 - Threshold change in luminance to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 44 - Threshold change in battery level to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 45 - Threshold change in ultraviolet to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 100 - configuration_parameter 100: Value was changed to 0 but not stored in device yet.
Nº 101 - Which report needs to be sent in Report group 1: Value was changed to 0 but not stored in device yet.
Nº 102 - Which report needs to be sent in Report group 2: Value was changed to 0 but not stored in device yet.
Nº 103 - configuration_parameter 103: Value was changed to 0 but not stored in device yet.
Nº 110 - Set 111-113 to default.: Value was changed to 0 but not stored in device yet.
Nº 111 - configuration_parameter 111: Value was changed to 0 but not stored in device yet.
3. Different info on expert/#/control/sensors and elements-page
Elements page shows:
Alarm Burglar 3-0-113-7-3 Aeon Labs
Alarm Burglar 3-0-113-7-8 Aeon Labs
Sensor General purpose 3-0-48-1 Aeon Labs
Sensor Humidity 3-0-49-5 Aeon Labs
Sensor Luminiscence 3-0-49-3 Aeon Labs
Sensor Temperature 3-0-49-1 Aeon Labs
Sensor Ultraviolet 3-0-49-27 Aeon Labs
3 Room General purpose Idle 14:39
3 Room Temperature 23.3 °C 14:39
3 Room Luminiscence 6 Lux 14:39
3 Room Humidity 35 % 14:39
3 Room Ultraviolet 0 UV index 14:39
