Configuration settings not stored, job queue not processed
Posted: 05 Dec 2015 17:21
I have a couple of "strange" things happening, but don't know if there're related (Aeotec Multisensor 6, gen 5).
1. Jobs queue looks like
and the log says:
and it's triggered every 10 minutes, so it makes sense that all events are removed since there already is entries in the log. But why are the entries in the log not processed? Does the timeout at 20sec really make sense? Shouldn't it be shorter or does lowering the timeout have other negative impacts?
expert/#/control/sensors-page that lists all sensors shows that the last update has been made at 14:39. I guess when the timeout at 20 has passed the entries in the log will be removed and the sensors updated when next 10min is triggered? But now the log shows:and the job queue still hasn't been emptied?
2. Configuration settings are not stored according to the expert/configurations page
is this because the sensor is asleep (it's on batteries)? What's the best way to configure this in that case?
3. Different info on expert/#/control/sensors and elements-page
Elements page shows:
but control/senesors:
shouldn't they show the same amount of sensors?
U W S E D Ack Resp Cbk Timeout NodeId Description Progress Buffer
0 W - - - 0.20 3 SensorBinary Get 3 2 30 2 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 1 0 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 3 8 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 5 0 5
0 W - - - 0.20 3 SensorMultilevel V5 Get 3 4 31 4 1b 0 5
0 W - - - 0.20 3 Alarm Get (v3) 3 5 71 4 0 7 0 5
Queue length: 6Code: Select all
[2015-12-05 15:00:00.259] [I] [core] --- ZWayVDev_zway_3-0-48-1 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.260] [D] [zway] Job 0x13 (SensorBinary Get): removing duplicate
[2015-12-05 15:00:00.261] [I] [core] --- ZWayVDev_zway_3-0-49-1 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.263] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.263] [I] [core] --- ZWayVDev_zway_3-0-49-3 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.264] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.265] [I] [core] --- ZWayVDev_zway_3-0-49-5 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.265] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.265] [I] [core] --- ZWayVDev_zway_3-0-49-27 performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.266] [D] [zway] Job 0x13 (SensorMultilevel V5 Get): removing duplicate
[2015-12-05 15:00:00.266] [I] [core] --- ZWayVDev_zway_3-0-113-7-3-A performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.267] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicate
[2015-12-05 15:00:00.268] [I] [core] --- ZWayVDev_zway_3-0-113-7-8-A performCommand processing: {"0":"update"}
[2015-12-05 15:00:00.269] [D] [zway] Job 0x13 (Alarm Get (v3)): removing duplicateexpert/#/control/sensors-page that lists all sensors shows that the last update has been made at 14:39. I guess when the timeout at 20 has passed the entries in the log will be removed and the sensors updated when next 10min is triggered? But now the log shows:
[2015-12-05 15:20:00.708] [I] [core] --- ZWayVDev_zway_3-0-48-1 performCommand processing: {"0":"update"}
[2015-12-05 15:20:00.709] [D] [zway] Job 0x13 (SensorBinary Get): removing duplicate
Configuration Settings
Nº 3 - default PIR time: Value was changed to 0 but not stored in device yet.
Nº 5 - command sent when the motion sensor triggered.: Value was changed to 0 but not stored in device yet.
Nº 41 - Threshold change in temperature to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 42 - Threshold change in humidity to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 43 - Threshold change in luminance to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 44 - Threshold change in battery level to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 45 - Threshold change in ultraviolet to induce an automatic report.: Value was changed to 0 but not stored in device yet.
Nº 100 - configuration_parameter 100: Value was changed to 0 but not stored in device yet.
Nº 101 - Which report needs to be sent in Report group 1: Value was changed to 0 but not stored in device yet.
Nº 102 - Which report needs to be sent in Report group 2: Value was changed to 0 but not stored in device yet.
Nº 103 - configuration_parameter 103: Value was changed to 0 but not stored in device yet.
Nº 110 - Set 111-113 to default.: Value was changed to 0 but not stored in device yet.
Nº 111 - configuration_parameter 111: Value was changed to 0 but not stored in device yet.
Alarm Burglar 3-0-113-7-3 Aeon Labs
Alarm Burglar 3-0-113-7-8 Aeon Labs
Sensor General purpose 3-0-48-1 Aeon Labs
Sensor Humidity 3-0-49-5 Aeon Labs
Sensor Luminiscence 3-0-49-3 Aeon Labs
Sensor Temperature 3-0-49-1 Aeon Labs
Sensor Ultraviolet 3-0-49-27 Aeon Labs
3 Room General purpose Idle 14:39
3 Room Temperature 23.3 °C 14:39
3 Room Luminiscence 6 Lux 14:39
3 Room Humidity 35 % 14:39
3 Room Ultraviolet 0 UV index 14:39
