I'm having a real horrid time getting my Aeon keyfob to work.
It used to work but since the z-way 2.2.0 update I noticed it just vanished. That's not to say the update is at fault, but it's odd.
I spent hours on this going as far as excluding all devices (I don't have that many yet), re-imaging, device factory reset, the lot, but still I cannot get the device to include properly.
I even restored z-way to the the Pi image 2.1.2, but still the same issue.
When including the following occurs:
[2015-12-26 10:33:43.370] [D] [zway] SETDATA controller.data.secureInclusion = True
[2015-12-26 10:33:43.391] [I] [zway] Adding job: Add/re-include node to network
[2015-12-26 10:33:43.398] [D] [zway] SENDING (cb 0x08): ( 01 05 00 4A C1 08 79 )
[2015-12-26 10:33:43.399] [D] [zway] RECEIVED ACK
[2015-12-26 10:33:43.408] [D] [zway] RECEIVED: ( 01 07 00 4A 08 01 00 00 BB )
[2015-12-26 10:33:43.408] [D] [zway] SENT ACK
[2015-12-26 10:33:43.409] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2015-12-26 10:33:43.409] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2015-12-26 10:33:43.409] [I] [zway] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2015-12-26 10:33:43.409] [D] [zway] SETDATA controller.data.controllerState = 1 (0x00000001)
[2015-12-26 10:33:51.013] [D] [zway] RECEIVED: ( 01 07 00 4A 08 02 00 00 B8 )
[2015-12-26 10:33:51.013] [D] [zway] SENT ACK
[2015-12-26 10:33:51.013] [I] [zway] Job 0x4a (Add/re-include node to network): Node found: #0
[2015-12-26 10:33:51.014] [D] [zway] SETDATA controller.data.controllerState = 2 (0x00000002)
[2015-12-26 10:33:53.808] [D] [zway] RECEIVED: ( 01 07 00 4A 08 07 00 00 BD )
[2015-12-26 10:33:53.809] [D] [zway] SENT ACK
[2015-12-26 10:33:53.809] [I] [zway] Job 0x4a (Add/re-include node to network): Failed
[2015-12-26 10:33:53.809] [D] [zway] Job 0x4a (Add/re-include node to network): fail
[2015-12-26 10:33:53.809] [I] [zway] Removing job: Add/re-include node to network
[2015-12-26 10:33:53.809] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2015-12-26 10:33:53.810] [I] [zway] Adding job: Add/re-include node to network
[2015-12-26 10:33:53.810] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4A 05 00 B5 )
[2015-12-26 10:33:53.818] [D] [zway] RECEIVED ACK
[2015-12-26 10:33:53.819] [I] [zway] Job 0x4a (Add/re-include node to network): Stop done
[2015-12-26 10:33:53.819] [D] [zway] Job 0x4a (Add/re-include node to network): success
[2015-12-26 10:33:53.819] [I] [zway] Removing job: Add/re-include node to network
[2015-12-26 10:33:53.819] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)I've replaced the battery, so it's not that.
I've followed the manual on how to reset the Keybob, i.e pressing the mode button with a pin for 20 seconds, then changed the mode from 'setup' to 'use', but still when trying to include the device the above occurs.
I've tried including via unsecure too, but the same problem.
Excluding the device works fine:
[2015-12-26 10:41:38.400] [I] [zway] Adding job: Remove node from network
[2015-12-26 10:41:38.401] [D] [zway] SENDING (cb 0x0c): ( 01 05 00 4B C1 0C 7C )
[2015-12-26 10:41:38.403] [D] [zway] RECEIVED ACK
[2015-12-26 10:41:38.412] [D] [zway] RECEIVED: ( 01 07 00 4B 0C 01 00 00 BE )
[2015-12-26 10:41:38.413] [D] [zway] SENT ACK
[2015-12-26 10:41:38.413] [D] [zway] SETDATA controller.data.lastIncludedDevice = Empty
[2015-12-26 10:41:38.413] [D] [zway] SETDATA controller.data.lastExcludedDevice = Empty
[2015-12-26 10:41:38.414] [I] [zway] Job 0x4b (Remove node from network): Ready to remove - push button on the device to be removed
[2015-12-26 10:41:38.414] [D] [zway] SETDATA controller.data.controllerState = 5 (0x00000005)
[2015-12-26 10:41:43.939] [D] [zway] RECEIVED: ( 01 07 00 4B 0C 02 00 00 BD )
[2015-12-26 10:41:43.939] [D] [zway] SENT ACK
[2015-12-26 10:41:43.939] [I] [zway] Job 0x4b (Remove node from network): Node found: #0
[2015-12-26 10:41:43.939] [D] [zway] SETDATA controller.data.controllerState = 6 (0x00000006)
[2015-12-26 10:41:43.940] [D] [zway] SETDATA controller.data.lastExcludedDevice = 0 (0x00000000)
[2015-12-26 10:41:44.701] [D] [zway] RECEIVED: ( 01 17 00 4B 0C 04 00 10 01 01 01 5E 86 72 70 80 84 85 59 73 5A EF 2B 26 73 )
[2015-12-26 10:41:44.702] [D] [zway] SENT ACK
[2015-12-26 10:41:44.702] [I] [zway] Job 0x4b (Remove node from network): Removing controller: #0
[2015-12-26 10:41:44.702] [D] [zway] SETDATA controller.data.controllerState = 7 (0x00000007)
[2015-12-26 10:41:44.702] [D] [zway] SETDATA controller.data.lastExcludedDevice = 0 (0x00000000)
[2015-12-26 10:41:44.713] [D] [zway] RECEIVED: ( 01 17 00 4B 0C 06 00 10 01 01 01 5E 86 72 70 80 84 85 59 73 5A EF 2B 26 71 )
[2015-12-26 10:41:44.713] [D] [zway] SENT ACK
[2015-12-26 10:41:44.714] [I] [zway] Job 0x4b (Remove node from network): Done
[2015-12-26 10:41:44.714] [D] [zway] Job 0x4b (Remove node from network): success
[2015-12-26 10:41:44.714] [I] [zway] Removing job: Remove node from network
[2015-12-26 10:41:44.714] [I] [zway] Adding job: Remove node from network
[2015-12-26 10:41:44.715] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)
[2015-12-26 10:41:44.715] [D] [zway] SENDING (cb 0x00): ( 01 05 00 4B 05 00 B4 )
[2015-12-26 10:41:44.723] [D] [zway] RECEIVED ACK
[2015-12-26 10:41:44.724] [I] [zway] Job 0x4b (Remove node from network): Stop done
[2015-12-26 10:41:44.724] [D] [zway] Job 0x4b (Remove node from network): success
[2015-12-26 10:41:44.724] [I] [zway] Removing job: Remove node from network
[2015-12-26 10:41:44.724] [D] [zway] SETDATA controller.data.controllerState = 0 (0x00000000)Any ideas?
